check engine light help
Old May 1, 2005 | 07:54 PM
gda777's Avatar
Default check engine light help
i have 92 civic h/b with b16a swap and ls ecu, i don't know if thats a good mix. but my check engine lights up after driving for a wile, and could anybody help how to check ecu for codes, were to look for blinking light, the check engine light go's on and stays on..
Old May 1, 2005 | 07:58 PM
civic-si-2000's Avatar
Default Re: check engine light help (gda777)
Maybe im missing something but why use an ls ecu? wouldn't you not have VTEC?
Old May 1, 2005 | 10:41 PM
hatchi's Avatar
https://honda-tech.com/zerothread?id=1171263
Also u need to get the right ecu for your swap
Old May 1, 2005 | 10:42 PM
JDMlyfestyle's Avatar
prime example of a dumbass that doesnt do research b4 attempting
You need a p30 ecu or a chipped p28 to be able to run the motor correctly.
Old May 2, 2005 | 09:11 PM
gda777's Avatar
i bought my b16 and the dude that was istalling it didn't switch the ecu i guess from a previous engine swat that was ls v-tec, before it was running good, then something just happend and the check engine light came on, and im not sure how to find the wires i need to jump to see my cell blink and to get the code. need help with what needs too be done, would my number one step be to change the ecu.?
hergizzal
Feb 10, 2010 02:34 PM
MattsGreenEG
Mar 19, 2008 09:21 PM
ImportPower13
26
Mar 3, 2005 03:31 PM
SolidSpruce
Apr 2, 2003 06:28 AM
phatcivic99
Jun 20, 2002 01:53 PM
