"Rattley" noise from my shifter......
Old May 1, 2005 | 07:45 PM
xEnderx's Avatar
Default "Rattley" noise from my shifter......
Put my B16B swap in yesterday and it runs great....after I drove home tonight the shifter became very "loose" and "rattley". It will still go into gear, but the shift lever itself seems to be sitting too far towards the rear of the car, and it just flo[ps around...I mean I can feel it hitting the unibody of the car when I push it to the left and right...doesn't take ANY effort to do that either. I dunno what is wrong, but I'm scared.
Old May 1, 2005 | 07:57 PM
Lord Helmet's Avatar
Default Re: "Rattley" noise from my shifter...... (xEnderx)
what shifter are you using oem or aftermarket?, looked under and see if it's touching anything? tighten up everything?
Old May 1, 2005 | 08:00 PM
Aphelion's Avatar
Default Re: "Rattley" noise from my shifter...... (sleeperciv)
Get under the car and wiggle it.
Old May 1, 2005 | 08:09 PM
hatchish's Avatar
yeah the rubber wedge came off and its probably sitting on your exhaust pipe use washers with the bolts on there and its golden
Old May 1, 2005 | 08:11 PM
xEnderx's Avatar
Default Re: (hatchish)
No light where the car is parked, and its too low to get under...plus no jack. I left all my toosl and stuff at home when I came out here for school. The rattle and stuff is in relation to how it feels......it still shifts ok, but its all loose. I just need some idea of what it is so that I can check it at school tomorrow.
Its an OE CTR shifter and shift linkage.
Old May 1, 2005 | 08:14 PM
hatchish's Avatar
just get under there u will see whats up literally.....
Old May 1, 2005 | 08:24 PM
nub.96ek's Avatar
Mine started rattling after I put in a short throw and bushings...everything is tight and shifts fine so I just turn up my stereo.
Old May 1, 2005 | 09:08 PM
Aphelion's Avatar
Default Re: (nub.96ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek &raquo;</TD></TR><TR><TD CLASS="quote">Mine started rattling after I put in a short throw and bushings...everything is tight and shifts fine so I just turn up my stereo.</TD></TR></TABLE>
Rofl. You could always do that.
Old May 1, 2005 | 09:20 PM
honda_S's Avatar
i put in and aftermarket short throw and it makes the same sound but it seems fine i also just turn up my radio
Old May 1, 2005 | 09:23 PM
xEnderx's Avatar
Default Re: (8y61d)
Maybe you misse dth part about it hitting the sides of the littel hole that the shift lever comes through. I can bang the hell out of the sides of it with the shifter itself. Screw it...I'll put it on a lift at school in teh morning.
Old May 3, 2005 | 12:04 PM
hatchish's Avatar
yeah mine did that 2 because it was coming apart
Old May 3, 2005 | 12:34 PM
xEnderx's Avatar
Easily fixed. The 12 mm bolts have TINY washers on them from teh factory. Honda can lick my *****. A pair of 5/16 flat washers seems to have made everythign nice and toight like a toiger again.
Old May 3, 2005 | 01:27 PM
hatchish's Avatar
see told ya
Nicks95GSR
Mar 24, 2007 05:46 AM
SiKSi2K
Nov 8, 2004 08:31 PM
Evilteg
Jan 19, 2003 03:16 PM
xaznx
Nov 1, 2002 10:12 AM
ActiveAero
Jun 29, 2001 03:08 PM
