Shifter Noise???
Wat it do you guys!!! I dont know why but my shifter (I dnt know the propper name) makes a shaking noise. For example everytime im on the free way going around 80MPH and I let go of the gas the (shifter) starts to shake. Is there something I can do to make it stop shaking? Whats wrong with it??? If you could please help me out on this that would be koo!!!
Thanks HT members!!!!
Is it the stock shifter? If its not hitting something then tighten it like jdmpurple_EK said, just don't do it too tight or you won't be able to shift!
IDK what its called but the collar around the middle of the ****(around the ball) broke when I was changing to a B&M I notice a nice piece of metal floating around.
just rattles slightly in every gear now.
I installed a tenzo-r in mine and it did the samething its just because the linkage is at a different angle now i was told that a new stabelizer bushing and linkage bushings help. Hey ask your buddys if when they installed it if they had to lowetr the exaust. cause wen i did mine i had to bend the hanger so it hung lower and even then it still rattled on the exaust, that also mite be the problem.
Delano5050
10
Feb 25, 2008 03:27 PM
Delano5050
11
Aug 20, 2007 12:40 PM
