Finished turbo now need help
Old Apr 30, 2005 | 08:56 PM
DMax013's Avatar
Default Finished turbo now need help
So i finished my turbo setup but now when i start the car up it fires right up and idles fine. But everytime i give it gas in gear it wants to stall out. Could this be a fuel problem? I am running 450 injectors i dont know what it is .. i have uberdata as well if someone knows please help
Old Apr 30, 2005 | 09:07 PM
null.'s Avatar
Default Re: Finished turbo now need help (DMax013)
could be too rich, is it fully tuned?
Old Apr 30, 2005 | 09:17 PM
xxtavixx's Avatar
Mhm...tricky one. Are you running any form of fuel control? That could be a problem. I'm not familiar with Hondas, but is it possible that your timing is being pulled too far off course? I would also double check all of the ignition components and gap on the plugs.
Old Apr 30, 2005 | 09:21 PM
DMax013's Avatar
Default Re: (xxtavixx)
I have the 450 injectors and im also running a walbro fuel pump my uberdata was programmed to reconize the injectors? could it be my o2 sensor?
Old Apr 30, 2005 | 11:51 PM
s2kdre's Avatar
Default Re: (DMax013)
basemap?
Old Apr 30, 2005 | 11:55 PM
Treblarefils's Avatar
Make sure the injectors are scaled right. Check over install again. It should work if everything is right.
Old May 1, 2005 | 06:54 AM
DMax013's Avatar
Default Re: Finished turbo now need help (Treblarefils)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Treblarefils &raquo;</TD></TR><TR><TD CLASS="quote">Make sure the injectors are scaled right. Check over install again. It should work if everything is right.</TD></TR></TABLE> How do I go about that?
xxrjxx
Apr 5, 2008 06:45 PM
digitalVinyl
Oct 25, 2006 05:52 AM
B18ceed
Apr 27, 2006 06:09 PM
cambopheonix56
Apr 1, 2005 04:23 AM
asianic415
Feb 12, 2004 08:11 AM
