How is a Del Sol Vtec??
I've been searchin for a honda/Acura and I want a Vtec. Well I've found several Del sol Vtec 1994, 5 speed, one person said it had 35k miles, which I doubt its the original engine.
But what do you guys think of this car, does it perform well? Do they get good gains from bolt ons?
I've been looking at Modacar looking for aftermarket parts for it and their isnt a Del Sol section, would I look under the civic section since they both have the same engine. Thanks
Its a del sol with a 2000 Civic Si motor.
It's a mid-high 15 second car stock. They get decent gains from bolt ons, probably could pull a 14.9 with full bolt ons and some good driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Its a del sol with a 2000 Civic Si motor.
could also be a VTEC model as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! »</TD></TR><TR><TD CLASS="quote">92-95 del sol = 92-95 civic... enginewise at least
del sols doesnt have the vtec-e
civics doesnt have the dohc VTEC
And to the guy, i compare the del sol VTEC to the 99+ si.
OK
93 had two models available s and si. S had a 1.6 sohc non vtec, si had 1.6 sohc vtec
from 94-97
there were three models s, si, and vtec. s and si were the same as previous and vtec had a b16a3. abs was optional
the advantage of 94 and 95 vtec is having obd1
As far as the body, the only change was the fog lights were on the 93-95
from 94-97
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfranknbeans »</TD></TR><TR><TD CLASS="quote">OK
from 94-97
As far as the body, the only change was the fog lights were on the 93-95</TD></TR></TABLE>
word. when people say 'del sol vtec' usually they are referring to the b16a3 del sol. but there is the d16z6 (sohc vtec) sol. but i believe all del sols were obd1.
from 94-97
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham »</TD></TR><TR><TD CLASS="quote">
word. when people say 'del sol vtec' usually they are referring to the b16a3 del sol. but there is the d16z6 (sohc vtec) sol. but i believe all del sols were obd1. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewp1 »</TD></TR><TR><TD CLASS="quote">But what do you guys think of this car, does it perform well? Do they get good gains from bolt ons?</TD></TR></TABLE>
The Honda CRX del Sol is a 2 seater targa top. It's slow like every other hatch out there, it's handling is horrible and it'll probably be hard to find parts.
And yes I own one and I love it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewp1 »</TD></TR><TR><TD CLASS="quote">I've been searchin for a honda/Acura and I want a Vtec.</TD></TR></TABLE>
even the CRV has VTEC... not just the del Sol. just pick what you like man!
well depending on what motor is in the car
if its got a d16z6 - its a good sohc motor that responds well to boost
if its got the b16a3 - its a good NA motor
but both could go the other way as well, so that is just my opinion... but its a good car to have, and not a lot of people have them either so its a good choice
I'm not sure where some of ya'll are getting your info, but there's a lot wrong on here.
93 did infact have only the S (only a 1.5 liter engine) and Si (packing the SOHC Vtec D16z6)
94 is when the DOHC Vtec model was first released.
95 minor mods to the sol included an incar trunk release and a fuel light
96-97 is when the biggest changes occured. The Sols ALL went to OBD II. They lost the Aux lights on the front end, and the S went to a non-vtec 1.6 liter engine.
And to answer your orignal question, the Vtec del Sol is a fun little car to drive. With some work, it can put down some good numbers. Course, you can do something in a Sol that you can't do in any other 90's Honda...GO TOPLESS!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sollecs »</TD></TR><TR><TD CLASS="quote"> Course, you can do something in a Sol that you can't do in any other 90's Honda...GO TOPLESS!!</TD></TR></TABLE>
I beg to differ, gimme a honda and a chainsaw, I'll get her to take her top off
but yea, sollecs is right
I'm currently on my second VTEC SOL (1.6 DOHC VTEC) and I love it.
In some respects the car is not the most practical because it has only two seats and minimal trunk space, but if you don't have a family or if it is a second car, its definitely one of the funner hondas out there.
No need to do a swap, no smog issues because it is the stock engine, and the ability to go topless in less than a minute! There are just as many upgrades for these engines because all b16 parts will fit and most suspension pieces from the EG (92-95 Civics) swap right over as well.
more accurate info than what these people are saying...
in the U.S., Del Sol's were made from 1993-1997.
93-95 Del Sol's (OBD1)...
Del Sol S - D15B7 SOHC non-VTEC - 102hp 98lbs/ft tq
Del Sol Si - D16Z6 SOHC VTEC - 125hp 106lbs/ft tq
94-95 Del Sol VTEC - B16A3 DOHC VTEC - 160hp 111lbs/ft tq
96-97 Del Sol's (OBD2a)
Del Sol S - D16Y7 SOHC non-VTEC - 106hp 103lbs/ft tq
Del Sol Si - D16Y8 SOHC VTEC - 127hp 107lbs/ft tq
Del Sol VTEC - B16A2 DOHC VTEC - 160hp 111lbs/ft tq
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sollecs »</TD></TR><TR><TD CLASS="quote">Course, you can do something in a Sol that you can't do in any other 90's Honda...GO TOPLESS!!</TD></TR></TABLE>
don't forget about the NSX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">more accurate info than what these people are saying...
Isn't good info wonderful
</TD></TR></TABLE>Isn't good info wonderful
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewp1 »</TD></TR><TR><TD CLASS="quote">I've been looking at Modacar looking for aftermarket parts for it and their isnt a Del Sol section, would I look under the civic section since they both have the same engine. Thanks</TD></TR></TABLE>
just search around. the parts are out there. if you can't find parts for your specific model, then parts from other civic/integra models can fit in a lot of cases. just remember the engine bay layout is nearly identical to that of most civics, and integras. most of the suspension and brakes also swap over too. so if you can't find parts just for your car, try buying the aftermarket for other cars. just make sure it fits before you buy it.
allmotorEG-SI
22
Dec 31, 2008 09:17 AM
LSracing94
48
Jan 28, 2008 11:14 PM
Spool Me Up
Sep 13, 2003 03:53 PM
