Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
upgraded to ITR brakes on my EG- something feels wrong
Old Apr 29, 2005 | 04:49 PM
project dc2's Avatar
Default upgraded to ITR brakes on my EG- something feels wrong
i got GSR knuckles with redrilled prelude rotors and accord wagon calipers, PBR semi metallic pads its a 92 si. i upgraded the MC to a 91 civic EX with is 15/16
anyways. my friends car has ITR brakes all around and locks the brakes up like nothing. my car however i just installed it BTW*
when braking. it grabs but i cant get it to lock up for ****. i can stand on top of the brakes. not gonna happen. any ideas ? im sure i could stand on top of the civic brakes and make them lock up.
i bled the brakes once. mebbe ill need to bleed them again ?
Old Apr 29, 2005 | 05:35 PM
mike-y's Avatar
Default Re: upgraded to ITR brakes on my EG- something feels wrong (project dc2)
what brake booster are you using?
stock civic?
Old Apr 29, 2005 | 06:07 PM
Default Re: upgraded to ITR brakes on my EG- something feels wrong (mike-y)
yes stock civic booster with a 91 honda civic EX master ( direct bolt on 15/16th)
Old Apr 29, 2005 | 10:01 PM
SD350z's Avatar
Bleed one more time to make sure, and if it doesnt work...go underneath the dash (need to remove driver's seat) and adjust booster from there.
Old Apr 30, 2005 | 12:32 PM
toEknEEg's Avatar
Default Re: upgraded to ITR brakes on my EG- something feels wrong (SD350z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD350z &raquo;</TD></TR><TR><TD CLASS="quote">Bleed one more time to make sure, and if it doesnt work...go underneath the dash (need to remove driver's seat) and adjust booster from there.</TD></TR></TABLE>
Old Apr 30, 2005 | 05:20 PM
paRRRker's Avatar
Default Re: upgraded to ITR brakes on my EG- something feels wrong (toEknEEg)
yeah...adjust the "wing lookin nut" on the booster...after you bleed like crazy 3 or 4 more times
Old Apr 30, 2005 | 06:10 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: upgraded to ITR brakes on my EG- something feels wrong (paRRRker)
Also, your brake pads suck. And your tires might be different than either your old ones or his. What's this brake booster adjustment thingy?
Old Apr 30, 2005 | 06:36 PM
1GreyTeg's Avatar
Default Re: upgraded to ITR brakes on my EG- something feels wrong (sscguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote"> What's this brake booster adjustment thingy? </TD></TR></TABLE>
We probably can't adjust ours for some odd reason.
If we can though, point me in the right direction.
Old Apr 30, 2005 | 07:47 PM
paRRRker's Avatar
Default Re: upgraded to ITR brakes on my EG- something feels wrong (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
If we can though, point me in the right direction.</TD></TR></TABLE>
when changing a brake booster, or simply looking up under your dashboard where a cable ties into the brake booster "wing nut thingy" and then goes to your brake pedal i think...it's been awhile since i have changed a booster, anyway, you can see a goldish adjustment screw type wing thing that can turn two ways...when i did my 4x100 itr front setup on the race car...i had to play with different adjustments on it for a few times before i got it just right...trial and error...it sucks...but what else is there to do?
also...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD350z &raquo;</TD></TR><TR><TD CLASS="quote">go underneath the dash (need to remove driver's seat) and adjust booster from there.</TD></TR></TABLE>
there is no need to remove driver seat for this...i don't see why...simply slide it back as far as the seat will go...then go under the dash...
Old May 2, 2005 | 03:38 AM
Suspetise...
What exactly does that adjust, stiffness of the booster or something? Or how much the booster helps?
Old May 2, 2005 | 08:59 AM
paRRRker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">What exactly does that adjust, stiffness of the booster or something? Or how much the booster helps?</TD></TR></TABLE>
to be honest im not exactly sure...it might be one of those or both of those because when i adjusted it too much the brakes were dragging...then a few turns back the other way and they were perfect and felt perfect.
Old May 2, 2005 | 09:24 AM
Suspetise...
Guess I'll have to fiddle with it then, thanks for the tip
Old May 2, 2005 | 09:28 AM
MattD@Stoptech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paRRRker &raquo;</TD></TR><TR><TD CLASS="quote">
to be honest im not exactly sure...it might be one of those or both of those because when i adjusted it too much the brakes were dragging...then a few turns back the other way and they were perfect and felt perfect. </TD></TR></TABLE>
It adjusts the clearance between the nipple in the booster and the piston connected to the brake pedal assembly.
Too much and the brakes drag, too little and there is noticable lag (amount of movement) between when the pedal is depressed and when the car actually starts braking.
Old May 2, 2005 | 10:12 AM
paRRRker's Avatar
Default Re: upgraded to ITR brakes on my EG- something feels wrong (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
Too much and the brakes drag, too little and there is noticable lag (amount of movement) between when the pedal is depressed and when the car actually starts braking.</TD></TR></TABLE>
thats what i figured...i dont know names of things but i know how to adjust them and the affects of the adjustments
Old May 2, 2005 | 10:40 AM
R you serious's Avatar
i seriously doubt its the master cylinder..rarely do those need adjusting.
make sure you are bleading the brakes in the correct sequence. sounds to me like you have an airbubble for sure..
Old May 2, 2005 | 11:41 AM
paRRRker's Avatar
Default Re: upgraded to ITR brakes on my EG- something feels wrong (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">i seriously doubt its the master cylinder..rarely do those need adjusting.
make sure you are bleading the brakes in the correct sequence. sounds to me like you have an airbubble for sure..</TD></TR></TABLE>
its not adjusting the master cylinder...its adjusting the booster...and when upgrading to a much bigger brake setup on the front...the booster could need adjustment like mine did to compensate for the bigger brakes up front.
FastAzzCivic
16
Aug 26, 2006 08:33 PM
AThiker
Nov 23, 2004 10:02 AM
EGTeK
13
May 6, 2003 07:02 AM
43MA
10
Feb 16, 2003 01:08 PM
