opinions needed on which turbo kit
Not a problem. I'd recommend going with this kit for your LS: http://www.importparts.com/sho...=2184
This was the kit I had on my 97 LS. It was the best two years of my Integra's life, 255whp and 220ft.lbs. of torque.
I highly recommend the kit from xs-engineering. For some reason it is often looked over, but it really is a great product. It uses the GT28RS turbo which is really great for low boost quick spooling setups. If you want you can go with xs's fuel management, but i only recommend doing that if there is a capable power-fc tuner near you. If not you can just get the turbo and **** and use hondata or uberdata.
If you would like more info on this kit or a dyno graph of it on my 99 gsr then send me an e-mail or look me up on aim.
EDIT: Didn't realize you had an ls.... MY BAD
It works great for small boost application, max 8psi. Beyond that, I'd recommend stepping up to a stand alone engine management system.
untitled
Dec 22, 2004 07:26 AM
