which is better for na build, close or open decked h22?
Old Apr 28, 2005 | 12:07 PM
GEIJIN's Avatar
Default which is better for na build, close or open decked h22?
i'm in the process of purchasing a h22 motor for my 97 civic dx 4door. i wanted to know which is better for going all motor. Is the open deck or closed deck motor. i keep hearing mixed resutls from people. any help is appreciated. thankx
Old Apr 28, 2005 | 01:14 PM
fastwanabe's Avatar
Default Re: which is better for na build, close or open decked h22? (fourdoorek)
all of the above.
Old Apr 28, 2005 | 02:21 PM
GEIJIN's Avatar
Default Re: which is better for na build, close or open decked h22? (fastwanabe)
ok so basically it doesn't matter? well i do know the SH tranny is $hitty. i'd go with a obd1 tranny. my friend personally has had both obd1 and obd2 tranny's and he said you can feel the difference. whether that is just him or a fact i'll have to find out...
Old Apr 28, 2005 | 10:00 PM
SixguN's Avatar
If you get a H22a4 SH, and have a Different tranny put on, You will need to fabricate a steel plate to mount the Mid shaft to the block because of the bolt pattern, if you didn't know that allready. I used a m2a4 tranny, with a 93 acord midshaft. It worked great while my engine was running.
Old Apr 29, 2005 | 07:57 AM
GEIJIN's Avatar
Default Re: which is better for na build, close or open decked h22? (Sixgundone)
thanks for the headsup. does you tranny pull harder than the stock H22?
Old Apr 29, 2005 | 10:27 AM
SixguN's Avatar
I couldn't really tell ya. It came with the swap I bought.
Old Apr 29, 2005 | 10:58 AM
fastwanabe's Avatar
your question was about the motor not the tranny. An H22 or A4 would work with the 5 speed tranny of any H22.
StockDC2
Aug 21, 2008 02:49 PM
CD8coupeSiR
May 12, 2006 04:00 AM
18gLUDE
Mar 2, 2005 03:45 AM
streetspeed607
Apr 12, 2004 12:54 PM
niedejb
Feb 25, 2002 06:58 PM
