5 lug coversion question
Old Apr 28, 2005 | 12:06 PM
xoutlawz00x's Avatar
Default 5 lug coversion question
i tried searching.. my friend is doin this on a ek 97 hacth and has a few questions..
1. does he need new prop vavle?? i head hacthes and si's prop valve are the same and u can use si's prop valve i heard..
2.what bushing kit should i get???
3. which master cylinder and brake booster can he use.. i heard gsr or type r is good.??
4.he has to get a rear camber kit for 96-00 civic right
Old Apr 28, 2005 | 12:18 PM
clint g's Avatar
Default Re: 5 lug coversion question (xoutlawz00x)
1. yes 99-00 prop valve will work
2. get one for the year of his car they all work I got gsr arms on my 93
3.Gsr or type r depends on the money ur friend has to spend
4.not sure on this one someone else could chime in
Old Apr 28, 2005 | 12:55 PM
Hollywoood's Avatar
Default Re: 5 lug coversion question (clint g)
Camber kit for 96-00 civic will work just fine!
Ryan
Old Apr 28, 2005 | 01:06 PM
Default Re: 5 lug coversion question (Hollywoood)
thanks
Old Apr 28, 2005 | 03:19 PM
for the abs can i just take it off do should i tuck it away
Old Apr 28, 2005 | 03:28 PM
ninjaEF's Avatar
1. get a 99-00 us si pp valve ctr's came with abs the ctr type-rx came without but hard to get.
2. bushings? 99-00 civic si??
3. get 98 up RS master and booster/ 99-00 civic master and booster 15/16 on the master....the jdm itr 98 spec is a 1 but you have to get a ss line because the hard line fitting is on the other side.
4. 94-up integra and 92-up civic share the came camber kit/ use longer bolts and washers
hope that helps
Old Apr 28, 2005 | 03:57 PM
TallAssFilipino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xoutlawz00x &raquo;</TD></TR><TR><TD CLASS="quote">i tried searching.. my friend is doin this on a ek 97 hacth and has a few questions..
1.) Are you talking about 99/00 Si's? I know I've confirmed with several Honda dealerships that the 99/00 Civic hatches share the same part # as the 99/00 Si's. Not sure on the 96-98 hatches though. On my friends 99/00 hatch, he didn't even bother changing his prop' valve. I would at the very least change the prop' valve, but like I said, Honda confirmed they shared the same part #'s. :::shrugs:::
2.) Energy Suspension? IDK.
3.) Not sure for the 6th gen' Civic hatches. On my friends 99/00 hatch, he didn't even bother changing it.
4.) You can use spacers for now.
Here's a pic I just took yesterday of my 5-lug on my 5th gen'...
Modified by MDJ IKNJ at 7:53 PM 4/28/2005
Old Apr 28, 2005 | 04:26 PM
itr-00-436's Avatar
</TD></TR></TABLE>you could use 99-00 gsr master works perfect on stock brakebooster bolts on rightup.im using si proport. valve you dont need no bushin
Old Apr 28, 2005 | 06:51 PM
Default Re: 5 lug coversion question (itr-00-436)
thanks fellas im paint my front end then throw the suspesion on ill let ya know how it went
Old Apr 28, 2005 | 08:11 PM
the reason i metioned busshing is cuase my back squeks
alltech_hybrid
Apr 5, 2006 11:09 PM
damnecheck
Jan 19, 2005 03:30 PM
ineedboostbad
13
Sep 27, 2002 10:15 AM
VSM EXtasy
Sep 26, 2002 12:34 PM
