brake porportion valve
Re: brake porportion valve (Spade)
Neither one are the same, but if you are doing a rear brake conversion on your 96-00 civic you will only need the proportioning valve from a 99-00 Si, forget about the master cylinder because there is not a lot of difference in the capacity of a 96-00 Civic EX and an Si prop valve. My suggestion is, only change out the master cylander(to a 94-01 integra MC) if you are getting larger front rotors and calipers.
aZnjCC
10-20-2006 05:21 PM
AZSTATEPOLICE
04-19-2006 07:47 PM
6SPD_EK
04-12-2004 06:57 AM
