Noob question: which cluster is this?
When i bought the car, the previous owner had already swapped in another cluster to get a tach (my car is a 94 cx hatch).... but what is it from?
Just curious.... thanks
Re: Noob question: which cluster is this? (Nytmair)
It's a VX cluster cause it only goes up to 8000 rpm. Also in the right circle. Underneath the temp gauges you can see that white square outlining which is the upshift light.
So... VX cluster.
So... VX cluster.
Re: Noob question: which cluster is this? (HyBriDcxR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyBriDcxR »</TD></TR><TR><TD CLASS="quote">It's a VX cluster cause it only goes up to 8000 rpm. Also in the right circle. Underneath the temp gauges you can see that white square outlining which is the upshift light.
So... VX cluster. </TD></TR></TABLE>
YES SIR.
YES SIR.
Hey where's the temp needle?
I also see that the guy before swapped over the little insert from the cx cluster. It's in between the right circle and middle circle. You can see where the upshift light should be for the cx cluster.
He didn't have to do that.
ahhh a VX... didn't even think of that. and my temp needle is broken off... but you can still get a general idea of where it's pointing.
another question.... so would that shift light still work (if it's hooked up) or would it be wrong/not work since i have a b18b in the car?
Re: (Nytmair)
that shift light, the little green arrow, tells you when to shift for best gas economy, so mine usually comes on around like 2800-3000 so unless you wanna shift you LS at 3 grand it really wont do nuttin to hook it up
Re: Noob question: which cluster is this? (tihul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tihul »</TD></TR><TR><TD CLASS="quote">looks to be out of a dx to me since red line is at 6k where a ex/si is at 7.2k</TD></TR></TABLE>
Dx= no tach . Vx, but I would personally get a Si or Ex.
Re: (Nytmair)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nytmair »</TD></TR><TR><TD CLASS="quote">yeah, but since i didn't pay for it, it works for me! haha</TD></TR></TABLE>
What about when it overheats and you don't know it till the head blows. I would recommend getting that fixed. A used cluster is like $20 CDN or lower.
you can see (more or less) where the temp needle is... it's broken off, but not completely, so it's easy to estimate the temp. I'd def be able to tell if it's overheaing. so no big deal
Re: (Nytmair)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nytmair »</TD></TR><TR><TD CLASS="quote">you can see (more or less) where the temp needle is... it's broken off, but not completely, so it's easy to estimate the temp. I'd def be able to tell if it's overheaing. so no big deal </TD></TR></TABLE>
Alright. I checked out your car and the progress thread. Looking good . I wish I had the money for some body work and new paint job. Ohwell, in time.
vx... you can get them cheap cause nobody wants the low 6k redline tach....
just put gauge faces on it and tada you got a higher redline, the tach has the same sweep just colored differently
ITRex
08-24-2008 04:14 PM
itsJDMyo
04-18-2004 10:18 PM
CIVIC dude
27
08-20-2003 09:50 AM
