timing light doesnt work on my car!?
Old Apr 27, 2005 | 06:13 PM
ludewithanh22's Avatar
Default timing light doesnt work on my car!?
Ive tried hooking up 2 different timing lights on my car and they dont work right. Work fine on other cars tested. The light kinda flickers a little then stops for a little then flickers some more, not in a pattern or anything. What could be the cause of this? I have aftermarket plugs and wires...
Old Apr 27, 2005 | 10:19 PM
CRXDrew's Avatar
You plug wire could be jacked up.
Are you providing power for it ok? Ground and Positive hooked up ok on ur car?
Old Apr 28, 2005 | 05:25 PM
Default Re: timing light doesnt work on my car!? (ludewithanh22)
Has any body had this problem? Could it be the distributor, it is rather old.
Old Apr 28, 2005 | 05:49 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludewithanh22 &raquo;</TD></TR><TR><TD CLASS="quote">Has any body had this problem? Could it be the distributor, it is rather old.</TD></TR></TABLE>
Give us a more detailed look at what setup you have on your engine, which engine, mileage, blah blah blah. That way we can give you a more detailed answer.
Old Apr 28, 2005 | 10:48 PM
sickerhatch's Avatar
Default Re: timing light doesnt work on my car!? (sleeperciv)
Iknow it sounds dumb but are you sure your putten it on the correct wire.
Old Apr 29, 2005 | 10:54 AM
Yeah ive tried all the plug wires and grounded it. I tried on a honda accord and a chevy malibu and it worked fine. I have a 92 honda prelude SI with a jdm h22a swapped. Engine was suppose to have 40-80k miles. I have ngk wires and plugs. No ignition upgrades. CAI and headers are only aftermarket upgrades.
Old Apr 29, 2005 | 05:38 PM
bump
Old Apr 29, 2005 | 05:39 PM
Default Re: (ludewithanh22)
I don't mean to insult your intelligences but you do know the #1 spark plug wire is on the other side of the engine right? Not the one next to the distributor.
Old Apr 30, 2005 | 06:46 PM
yes i tried every spark plug wire
Old May 1, 2005 | 04:58 AM
NJIN BUILDR's Avatar
Sounds like the inductive pickup can't get a signal thru the ngk wires.The timing light pickup may just not be sensitive enough.Try a stock wire on the number one cylinder to time it (even a used one out of the junk yard).
Glenn
Max_GI
Dec 29, 2007 07:39 PM
px_R
May 24, 2006 12:27 PM
Griffins_Importuning
Oct 1, 2002 04:15 PM
EGHatchy
Jul 24, 2002 10:33 AM
conorm
Mar 6, 2002 03:47 PM
