d15b starting problems
Old Apr 27, 2005 | 12:45 PM
tsjeff's Avatar
Default d15b starting problems
I'm having problems with my motor. It turns over but it doesn't fire up. I got a new battery, so I don't think that is a problem. Any suggestion guys? It's a Del sol with a jdm d15b vtec w/z6 intake manifold. thanks in advance
Old Apr 27, 2005 | 12:46 PM
e jay one's Avatar
Default Re: d15b starting problems (9 3 d e l s o l)
check for fuel and spark then go from there.
Old Apr 27, 2005 | 12:51 PM
FERIOkid's Avatar
Default Re: d15b starting problems (e jay one)
make sure you didn't put the dizzy on 180 degrees backwards, i known it sounds dumb but i've seen it done. Not the distributor itself but the drive comming out of it that goes into your camshaft. And of course check for spark and fuel. Good luck.
random questions:
does the starter make noise?
does the car just click and thats it?
do you have a puel pressure guage?
did it run before or did you just do the swap?
if it ran before,, what did you try and do?
Old Apr 27, 2005 | 01:38 PM
tsjeff's Avatar
Default Re: d15b starting problems (slowdx9585)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 &raquo;</TD></TR><TR><TD CLASS="quote">make sure you didn't put the dizzy on 180 degrees backwards, i known it sounds dumb but i've seen it done. Not the distributor itself but the drive comming out of it that goes into your camshaft. And of course check for spark and fuel. Good luck.
random questions:
if it ran before,, what did you try and do?</TD></TR></TABLE>
Starter makes noise, when it tries to turn over.
No clicking, just trying to fire up.
no pressure gauge
just did the swap
I will try to see if there is any fuel going into the motor. (Any suggestion on how to do this?)
I will also be checking the dizzy
Old Apr 27, 2005 | 03:03 PM
FERIOkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9 3 d e l s o l &raquo;</TD></TR><TR><TD CLASS="quote">
no pressure gauge
just did the swap
I will also be checking the dizzy</TD></TR></TABLE>
take off the line to the fuel rail and crank the motor, just make sure you have a rag under it.
4ghatch
12
Mar 30, 2007 01:41 PM
vance desalvo
Jan 3, 2007 10:00 PM
aljayALLday
May 26, 2005 08:43 PM
project civic
Mar 10, 2005 08:35 AM
SaTownTegGsr
Sep 2, 2004 10:50 PM
