Gah... Wiring question... HELP NEEDED!
IAT sensor question(s)
any help is apresh
well i have a wiring question. First the setup:
99 SI ecu
99 Wireharness
98 USDM ITR motor.
My problems comes from a a code #10 IAT (internal air temp) senor.
More setup. Tegs have the IAT senor mounted inside the intake manifold, SI's have theirs on the intake pipe itself.
When i did this swap i had the code from the start. I replaced the sensor in the manifold, no luck. So I started thinking. Well the air is cooler in the intake than the manifold, so maybe the ECu is seeing a higher temp from this ecu then it should, so i pull the plug and lengthen the wires and threw it in intake, that didn't work. Then i tried the same thing with a push in style IAT sensor (the kind that normally push in the intake). Again no luck.
Few stipulations:
the wire's on the harness didn't match the push style sensor, so it could be as simple as switching the wires, although i doubt it. But im trying that today and rechecking the wiring itself, but im sure it's fine.
aside from that, i'd love to hear some ideas on what this could be.
Now in addition, the plan to move to obd1 and a p28 on hondata. How does this problem relate to that. Can it be taken care of on the ecu side, if i can't get any more ideas on trouble shooting it.
any help is apresh
99 SI ecu
99 Wireharness
98 USDM ITR motor.
Few stipulations:
dividedas1
May 28, 2009 11:22 AM
