d15b swap into vx civic dizzy question.
Old Apr 26, 2005 | 09:38 PM
d15b's Avatar
Default d15b swap into vx civic dizzy question.
I own a 1992 vx civic and want to buy a d15b engine for it I have just found one for sale but without a dizzy. So I am wondering do I need this dizzy for the engine swap or is the original one ok. the original engine was a 1500 vtec_e.
Thanks
Old Apr 26, 2005 | 09:41 PM
Cuong-nutz's Avatar
Default Re: d15b swap into vx civic dizzy question. (d15b)
When you say D15B, you mean the Vtec one? Anyhow, IIRC, the VX dizzy is the same as the Z6 dizzy. So... yes you can reuse your old dizzy. Someone will chime in to confirm
Old Apr 26, 2005 | 09:54 PM
d15b's Avatar
Default Re: d15b swap into vx civic dizzy question. (Cuong-nutz)
what will I need for the swap then I no i need a new ecu but can I keep all the original vx manifolds and all that other stuff.????
Old Apr 26, 2005 | 11:34 PM
Calvinator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15b &raquo;</TD></TR><TR><TD CLASS="quote">what will I need for the swap then I no i need a new ecu but can I keep all the original vx manifolds and all that other stuff.????</TD></TR></TABLE>
I can confirm that your vx dizzy will work fine on the d15b. You can use your original vx manifolds, but I would highly recommend upgrading to a z6 or y8 intake manifold, since they can be bought for so cheap now a days. The stock vx manifold ports and plentium are tiny, and the throttle body is like 50mm, haha
Old Apr 26, 2005 | 11:54 PM
Uncle Ben's Avatar
Default Re: d15b swap into vx civic dizzy question. (xtremeazian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">and the throttle body is like 50mm, haha</TD></TR></TABLE>
More like 35ish, horrible lol. Also, wouldn't the 5 wire o2 interfere with the swap?
Old Apr 27, 2005 | 03:16 PM
McLovin's Avatar
Default Re: d15b swap into vx civic dizzy question. (Uncle Ben)
yes... u would need to convert to a 4 wire o2 sensor.
Old Apr 27, 2005 | 03:19 PM
snoochtodanooch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuong-nutz &raquo;</TD></TR><TR><TD CLASS="quote">When you say D15B, you mean the Vtec one? Anyhow, IIRC, the VX dizzy is the same as the Z6 dizzy. So... yes you can reuse your old dizzy. Someone will chime in to confirm </TD></TR></TABLE>
Doed
21
Jan 25, 2013 06:49 AM
fogged306
Jan 31, 2008 04:26 AM
CHK4TIX
Dec 4, 2006 06:20 AM
Unit02VXHatch
Jun 26, 2004 02:43 PM
Forrest Gump 9
May 25, 2003 04:20 PM
