Rotten Egg Smell
Old Apr 26, 2005 | 06:32 PM
Dohc.MAD's Avatar
Default Rotten Egg Smell
Well i was coming home from work and I was parking my car in the garage it's a 1999 civic SI with a stock B16 just with intake and a Kn&n filter. I periodically pop my hood from time to time just to make sure everything was aok and rev up not to high just till about 2400 just to make sure every thing is cool. Well after i shut it down i could smell a rotten egg smell emitting from the rear. My question is how come anyone have any ideas ?? I recently put a set of wires and plugs in and my Kn&N filter is a bit bigger but that shouldn't make much of a differance should it ??
Thanks for the help in advance
Old Apr 26, 2005 | 06:37 PM
r3p00c's Avatar
Default Re: Rotten Egg Smell (civic 2ner)
most likely a rotten egg smell is from a clogged/bad catalytic converter. check that out, that should be your problem!
Old Apr 26, 2005 | 06:46 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Rotten egg smell could be caused by a bad cat but it could be a series of problems you got going on there. The smell from the exhaust is not a sign of a bad cat. is a sign of the kind of improper mixture that will ultimately cause your cat to go bad. Before replacing the cat, look into the kinds of problems that can cause improper mixture such as a faulty o2 sensor
Old Apr 26, 2005 | 06:48 PM
kX's Avatar
kX
could be from a cat. my dad had that a while ago
Old Apr 26, 2005 | 06:51 PM
Tony_EM1's Avatar
sounds like a bad cat to me dude... i have a 2000 civic si and had the same problem.. i changed the cat and the smell was gone...
Old Apr 26, 2005 | 08:10 PM
dohcVTECeg2's Avatar
Default Re: Rotten Egg Smell (code415)
sounds like somebody cut the mustard
Old Apr 26, 2005 | 08:14 PM
HBK GABE's Avatar
Default Re: Rotten Egg Smell (dohcVTECeg2)
Almost all the time, it is the cat.
Old Apr 26, 2005 | 08:16 PM
Farmer Brown's Avatar
Default Re: Rotten Egg Smell (626CivicSi)
Cat. Meow...
Old Apr 26, 2005 | 08:18 PM
ZacCarter's Avatar
It's either the cat or the battery. When batteries go bad they emit sulfuric gases.
Old Apr 26, 2005 | 09:27 PM
cpforyou's Avatar
Default Re: (ZacCarter)
u sure u don't got a rotten egg in your trunk? =P
Old Apr 26, 2005 | 09:33 PM
eejay8girly's Avatar
that sucks..hope u figure it out...lots of air freshners coming ur way
Old Apr 26, 2005 | 09:36 PM
DrifteR8969's Avatar
Default Re: (eejay8girly)
some new exhausts have emmisions were for some reason it smells like rotten eggs. It's supposably comes cleaner but the smell is the con.
Old Apr 26, 2005 | 09:57 PM
Bond's Avatar
Default Re: (DrifteR8969)
check O2 sensor and cat and replace if nessecary. Your problem should go away.
Old Apr 27, 2005 | 12:54 AM
rasinhell's Avatar
Default Re: Rotten Egg Smell (r3p00c)
what if someone threw an eg in your exhaust.
Old Apr 27, 2005 | 12:57 AM
ek9800's Avatar
Default Re: Rotten Egg Smell (Richard D. James)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Richard D. James &raquo;</TD></TR><TR><TD CLASS="quote">Cat. Meow...</TD></TR></TABLE>
Old Apr 27, 2005 | 04:42 AM
Dohc.MAD's Avatar
Default Re: (Bond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond &raquo;</TD></TR><TR><TD CLASS="quote">check O2 sensor and cat and replace if nessecary. Your problem should go away.</TD></TR></TABLE>
thanks i think this is gonna be my best bet am most likly gonna check my 02 sensor with an OHM meter and see whats going on with my cat.
Thanks for the tech help.
And a little good old fashion H-T humor never hurts either
mortificationrock
12
Jan 28, 2010 12:09 PM
CRISIS
Apr 12, 2006 04:31 AM
Project_EK
41
Jun 9, 2005 05:49 AM
quik2kSi
Oct 4, 2003 10:10 AM
BlueSi2k
Mar 25, 2002 02:31 PM
