Cutting moons into piping. HOW TO?
IM putting together a cage and dont have a cutter to moon cut the ends of my
pipes. Any cool tips or tricks on doing that so the pipes but together perfectly???
I was just using my grinder, but it takes forever.
I've heard of people drawing two lines (to make a triangle) into the end of the pipe, cut with a chop saw and grind out to neccessary spec. This would probably be the last way you would want to do it, but it's an option.
http://www.blmgroup.com/img/pr...o.wmv
Go big, or go home, eh.
Laser Notcher, End Mill, Hole Saw, Die grinder, bench grinder, there's a ton of ways to do it.
Cool tips - Be patient.
After you've done it enough, you don't even need a sharpie, you can just see the notch.
I would hope that if you were building a cage, you would have done this before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delinquent »</TD></TR><TR><TD CLASS="quote">
cheap and works well enough to get the job done.
http://www.harborfreight.com/c...35782</TD></TR></TABLE>
Yeah, just cut slow and invest in some good saws.
im not trying to cut the pipes, i just need them moon notched.
No, i have never built a cage, thats why i am buying a pre built cage that just needs to be welded together.
