proper oil pump for ls vtec
Old Apr 25, 2005 | 07:34 PM
turbo_b16_ex's Avatar
Default proper oil pump for ls vtec
Im running b16 oil pump on ls vtec and at idle my oil light comes on. Does the b16 oil pump have enough pressure for my oil feed and my ls-vtec oil line? As soon as I give it a little gas the light goes away.
Old Apr 25, 2005 | 08:02 PM
bump
Old Apr 25, 2005 | 08:04 PM
Andres-eh2's Avatar
From what i have understood, your supposed to use a 1.8 vtec oil pump for ls/vtec. Did you check the oil sensor? might be loose?
Old Apr 25, 2005 | 08:11 PM
if the oil sensor was loose, wouldnt it leak? im just curious of whether ive got to much oil to spread around on a b16 oil pump
Old Apr 25, 2005 | 09:25 PM
SwappedTURBOegg's Avatar
Default Re: (turbo_b16_ex)
i have seen the b16 oil pump used many times with no problems.
Old Apr 26, 2005 | 08:00 AM
Andres-eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_b16_ex &raquo;</TD></TR><TR><TD CLASS="quote">if the oil sensor was loose, wouldnt it leak? im just curious of whether ive got to much oil to spread around on a b16 oil pump</TD></TR></TABLE>
Well its where the engine harness plugs into the sensor is what i mean. if your looking at the motor from behind, its usually to the left of the filter. If anything it just may be going bad.
Old May 2, 2005 | 11:59 AM
SL0WEGG's Avatar
Default Re: (Andres-eh2)
ive checked on acuraautomotive parts and the ls,gsr, type r oil bump have the same part numbers. so i dont know
edit: just checked again. only 96-01 ls pumps are the same as the vtec pumps. 94-95 i guess have to change oil pumps
Vtecme92
Jul 10, 2006 06:27 PM
caspers_hatch
Nov 12, 2005 11:37 PM
EG6R
Apr 17, 2005 08:35 PM
