proper oil pump for ls vtec
Im running b16 oil pump on ls vtec and at idle my oil light comes on. Does the b16 oil pump have enough pressure for my oil feed and my ls-vtec oil line? As soon as I give it a little gas the light goes away.
Re: (turbo_b16_ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_b16_ex »</TD></TR><TR><TD CLASS="quote">if the oil sensor was loose, wouldnt it leak? im just curious of whether ive got to much oil to spread around on a b16 oil pump</TD></TR></TABLE>
Well its where the engine harness plugs into the sensor is what i mean. if your looking at the motor from behind, its usually to the left of the filter. If anything it just may be going bad.
Re: (Andres-eh2)
ive checked on acuraautomotive parts and the ls,gsr, type r oil bump have the same part numbers. so i dont know
edit: just checked again. only 96-01 ls pumps are the same as the vtec pumps. 94-95 i guess have to change oil pumps
Vtecme92
07-10-2006 06:27 PM
caspers_hatch
11-12-2005 11:37 PM
