help on a ls swap in my civic
i am currently swaping a 96 ls in to my 96 ex and dont know what to do about the wiring harness i have been told by several different peps that i need to have the harness converted and also that i need to us the ls harnesss...... what do i do... help
If your Ls has an OBD2 like your ex has then it should be plug in play. I would get an ECU designed for the engine and maybe even a harness. Everything should be non vtec. You don't want to keep the same ECU you have and make the computer look for vtec when you have no connector to plug it in to.
Nothing needs to be converted. You need to transfer the Y8 harness onto the LS. You will have to extend a few plugs but that's it. The LS harness is useless for an EK chassis, sell it and make a few bux.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Clash »</TD></TR><TR><TD CLASS="quote">Nothing needs to be converted. You need to transfer the Y8 harness onto the LS. You will have to extend a few plugs but that's it. The LS harness is useless for an EK chassis, sell it and make a few bux.</TD></TR></TABLE>
Exactly, always use your old harness.
i have the ls ecu and can easily get the wiring harness from the ls.. so should i just use the ls ecu and the ls harness and it will be all fine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Normielove »</TD></TR><TR><TD CLASS="quote">i have the ls ecu and can easily get the wiring harness from the ls.. so should i just use the ls ecu and the ls harness and it will be all fine?</TD></TR></TABLE>
are u LISTENING? u only need the ls ecu. not the ls harness. its because the EK harness was designed to plug into B series motor (2000 SI b16). all u need to do is extend some wires.
YOu will need motor mounts (99-00 SI motor, frame, and block mounts), axles (LS axles will do fine), LS ECU (if its an OBD1 motor then you will need an ECU jumper), and you'll need to modify your harness. Read the B sereis conversion walkthrough's in the FAQ sticky.
yep just extend the wires from the stock harness make sure you soder them together dont tape them. get the LS axles and 99 Si mounts and you said you have the LS ecu I take it, its the one thats from the motor so you should have everything that you need then. you have the LS shift linkage also your gonna need that you cant use your stock linkage.
so correct me if im wrong...
Shopping List:
1.99-00 Si Mounts Drivers side upper and rear tranny
2.LS Axels
if anyone has the these items hit me back i need them asap
I live in WA can someone point me towards a shop that can do my harness work... would rather pay then **** something up!!
Shopping List:
2.LS Axels
Jlo96Hatch
Jul 19, 2004 10:03 AM
