12.1 c/r good for turbo
Old Apr 24, 2005 | 10:30 AM
lsvtec90's Avatar
Default 12.1 c/r good for turbo
i try searching but cant find it or not sure what to look for. wanting to go turbo with my lsv w/ 12.1-1 c/r. is it safe to go boost that high. everything is pretty much stock oem parts. what will i need to do to go boost like my timing, and what to control the turbo?
Old Apr 24, 2005 | 10:34 AM
J337_UNIT's Avatar
Default Re: 12.1 c/r good for turbo (lsvtec90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec90 &raquo;</TD></TR><TR><TD CLASS="quote">i try searching but cant find it or not sure what to look for. wanting to go turbo with my lsv w/ 12.1-1 c/r. is it safe to go boost that high. everything is pretty much stock oem parts. what will i need to do to go boost like my timing, and what to control the turbo?</TD></TR></TABLE>
thats a pretty high c/r for boost, but its been done. you need some good engine fuel management, and damn good tuning. what to control the turbo? how about a wastegate and a boost controller, or just a spring.
Old Apr 24, 2005 | 12:03 PM
02viclx's Avatar
Default Re: 12.1 c/r good for turbo (J337_UNIT)
its ganna be a bitch to tune at 12.1:1
Old Apr 24, 2005 | 02:26 PM
StolenTeg's Avatar
Default Re: 12.1 c/r good for turbo (02viclx)
It already hard tuning 12:1 all motor using 93 oct, let alone tuning 12:1 with boost
Old Apr 24, 2005 | 04:13 PM
Tony the Tiger's Avatar
What's the highest octane pump gas available in your area? You don't want to run race gas everyday
Old Apr 24, 2005 | 05:19 PM
lsvtec90's Avatar
Default Re: (Tony the Tiger)
90 octane and i was thinking that if i could use a vafc to tune it for now until i save up to get a better fuel mangement system. iwas thinking that if it is possible i will run about 7 to 9 psi for a while.
Old Apr 24, 2005 | 05:26 PM
StolenTeg's Avatar
Default Re: (lsvtec90)
What of piston do you have in your motor and there no way your gonna be safe running on 90 octance and afc
Old Apr 24, 2005 | 05:50 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec90 &raquo;</TD></TR><TR><TD CLASS="quote">90 octane and i was thinking that if i could use a vafc to tune it for now until i save up to get a better fuel mangement system. iwas thinking that if it is possible i will run about 7 to 9 psi for a while.</TD></TR></TABLE>
NO, do not run a VAFC at any amount of boost. Don't run a VAFC @ 12:1 compression PERIOD. 9 psi on 12:1 compression with a VAFC and your motor will be in pieces the first time you hit boost, end of story. You can't pull any timing with a VAFC, and that's what you need to keep your motor from destroying itself.
Hell, I wouldn't feel comfortable running a 12:1 motor naturally aspirated on 90 octane. Get lower compression pistons before you try anything.
Old Apr 24, 2005 | 07:12 PM
m R g S r's Avatar
so much to learn, so much to learn
Old Apr 24, 2005 | 07:29 PM
-iLLuZioN-B18C1's Avatar
90 octane + vafc + 7-9 psi + 12.1 CR???
good luck man.
seriously, i would try lowering the CR with at the LEAST a thicker hg. but get new pistons.
Old Apr 24, 2005 | 10:09 PM
lsvtec90's Avatar
Default Re: (m R g S r)
that is why im here asking you guys for help n e ways thinks for the help maybe ill try something else
Old Apr 24, 2005 | 10:17 PM
hondaeg8's Avatar
what is a good compression to run boost.... what is the highest compression to run it.
i think the 12 range is kinda high for boost.
Old Apr 25, 2005 | 01:27 PM
Default Re: (hondaeg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">what is a good compression to run boost.... what is the highest compression to run it.
You really have a lot to learn. How did you end up with your current motor anyways? 12.1:1 is already high enough compression for an NA setup with 90 oct. That thing can probably blow up without the boost
Old Apr 25, 2005 | 03:32 PM
to get you started there are a few things you can do.
do it right and buy new pistons w/ lower CR around 9.1-9.7 IMO
or the cheaper way and just buy a thicker headgasket.
dont waste your money on vafc and just go ahead and get hondata,uberdata ect
once you have it complete run the highest octane you state has
other than that you will need your basic turbo kit(ie turbo, wastegate,blowoff valve, eshaust manifold,ic and piping)
racing clutch
550cc injectors are a good start
those are pretty much your basics
i might be missing something...
then get it tuned right
Old Apr 25, 2005 | 08:35 PM
lsvtec90's Avatar
Default Re: 12.1 c/r good for turbo (-iLLuZioN-B18C1)
thanks for the hints or help everyone maybe ill start with the bottom and lower the c/r
Old Apr 25, 2005 | 08:41 PM
Cramerox's Avatar
I would just like to add that it is possible to run 12:1 it may not be the kind of car you want to drive everyday- maybe a track car.
Old Apr 25, 2005 | 09:30 PM
Default Re: 12.1 c/r good for turbo (Cramerox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox &raquo;</TD></TR><TR><TD CLASS="quote">I would just like to add that it is possible to run 12:1 it may not be the kind of car you want to drive everyday- maybe a track car.</TD></TR></TABLE>
it is possible but given his conditions of 90 octane, vafc, 12.1 CR was not a good combination
Old Apr 25, 2005 | 11:18 PM
Hell you can make the car run at 13:1 with a VAFC if you wanted to, but it will never run well. I bet we all could spin that dizzy to full retard and yay, the engine will run. It would just be slower than stock...
VAFC and 12:1 = suicide (for the motor) No timing control with high compression, what are you thinking? hah
matt11583
Feb 8, 2006 06:11 PM
brasilstreet
Jun 16, 2004 02:21 PM
smallttocs
Feb 22, 2003 09:47 AM
FATBOYYEG6
Dec 17, 2002 06:29 PM
