Oil Lead WTF!?!?!?!
LEAK!!!! mybad
Ok, i have never seen an oil leak like this before. But oil is coming out of the radiator hose and i'm not positive but, i think the intake manifold also. I just loosened up the head and oil is running all down the block where it is connected to the head. I haven't taken it off yet to inspect everything closely, but i will do that tomorrow morning. The thing is i got the head from a guy who was doing an ls vtec motor, so the head was prepped for that. But the head is not on a ls block its on a vtec GSR block. And i thought all the holes that were drilled were plugged up, and the ones that were plugged up, were back unplugged, to fit just like the normal stock head would, which is GSR too by the way. But as soon as i'm done with the removal, i'll take pictures of the head to show someone experienced with this to see if the head is properly back in order to fit on the vtec block. And also to show where else the oil found its way into. Much help is needed here guys. Thanks a lot.
Modified by ToyoSupraRZ at 5:41 AM 4/23/2005
Ben Petrocelli
May 4, 2019 04:46 AM
saemoonyang
12
Jun 7, 2010 02:01 PM
