running 5-8 psi
Old Apr 22, 2005 | 06:14 PM
redlseg's Avatar
Default running 5-8 psi
i got a poormans type r and i was wondering if i turbo the motor with that low of boost will i have to get a engine management system?
Old Apr 22, 2005 | 06:20 PM
oxSLEEPERxo's Avatar
Default Re: running 5-8 psi (95eg6allmotor)
you need a fuel management system
Old Apr 22, 2005 | 08:02 PM
blackeg's Avatar
Default Re: running 5-8 psi (oxSLEEPERxo)
generally 5-8 psi will be ok, but....you still need management. did you put the b16 pistons in your motor? high compression and turbo doesnt get along as well as low compression
Old Apr 22, 2005 | 08:12 PM
redlseg's Avatar
Default Re: running 5-8 psi (blackeg)
the stock gsr pistons are still in the block. with that low of boost can i use a vafc for my management? also can i still use the stock injectors or do i have to upgrade them?
Old Apr 22, 2005 | 09:37 PM
blackeg's Avatar
ok then your compression ratio is 9.8:1, which is boostable.
the vafc changes the signal that your map sensor sends to your ecu, which makes the ecu think you are running less load then you are and it advances your ignition timing. IF you run the vafc, use like dsm 450's or similar sized injectors and set the fuel values for your boost rpms to -30%. then u can tune from there. i will advise against this though, and to go to a rom program such as uberdata or turboedit if you are obd0
Old Apr 23, 2005 | 10:52 PM
redlseg's Avatar
alright cool thanx blackeg . i was also wondering if i run 8 maybe 10 psi how much more hp will i get out of my poormans type r? i ran it on a dyno and i was at 168hp
Old Apr 24, 2005 | 06:54 AM
blackeg's Avatar
a real rough estimate is that your car will make about 10 horsepower per 1 psi you run, so like 8 psi would give you an additional 80 hp and so on... its a really general way of thinking.
Old Apr 24, 2005 | 07:43 AM
redlseg's Avatar
alright cool thanx bro
wc4ohio
Apr 13, 2011 01:54 PM
hatchedzex
Dec 23, 2004 10:48 AM
b18cya
Feb 24, 2003 07:55 PM
gtconcepts
Dec 19, 2002 06:11 PM
ZCPOWER
Aug 1, 2002 01:44 PM
