difference between .48 stage III or V, and standard .63 AR exhaust housing?
Old Apr 22, 2005 | 06:10 PM
mrbsponge's Avatar
Default difference between .48 stage III or V, and standard .63 AR exhaust housing?
how much of a difference in flow in there from a stage 3 or 5 .48 housing versus a .63 standard exhaust housing.
what are the stages and how do they affect the turbos performance???
Old Apr 22, 2005 | 08:26 PM
mrbsponge's Avatar
did you try both of these by any chance???
and which .48 is it, standard, stage??
thank you BTW
Old Apr 23, 2005 | 05:28 AM
mrbsponge's Avatar
is there any given power numbers that can be made on AR exhaust housings????
i mean will a .63 support XXX.xx HP???????
Old Apr 23, 2005 | 05:42 AM
Flr Power's Avatar
Default Re: (mrbsponge)
My .48 spooled 200 rpm earlier but the .63 made a bit more power from mid range all the way to the top. I think the .63 is better for higher boost cause it flows more.
Old Apr 23, 2005 | 07:57 AM
mrbsponge's Avatar
was that on a B series or a D series?
what power levels were you achieving with either?
Old Apr 23, 2005 | 03:55 PM
Si Shane's Avatar
Default Re: (jeremyG2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeremyG2teg &raquo;</TD></TR><TR><TD CLASS="quote">
It is a typical stage 3.
Yes I have. I ran it on my stock bore B18B with 8.8:1 compression and a stage 3 57 trim T04B.
The .48 starts to make possitive pressure right around 2k RPMs and hits full boost (1 bar) by 3 to 3.5k.
I don't have any numbers for you as far as power is conserned, but the .48 does start to die out from 7-8k. It also powered my car (.90bar at the time) to a 13.5 @ 110.8 mph with a 2.327 60ft.
Hope all that helps a little. </TD></TR></TABLE>
VTEC head?
Also, how would you compare this turbine (in size, and flow) to a td05?
Old Apr 23, 2005 | 07:14 PM
mrbsponge's Avatar
thanks guys!
i have the .63 AR hot side on my turbo B16 now, but it has a very aggressive compressor wheel that i dont like, right now i get almost full boost at 5000-5100 rpms, i want something a little better spooling
also this is in a "B" housing, i think an "E" with a 60 trim would do the trick tho
Old Apr 23, 2005 | 08:35 PM
rjardy's Avatar
Default Re: (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">VTEC head?
Jeremy's motor is all LS (non vtec head)
Rob
Old Apr 24, 2005 | 08:05 AM
mrbsponge's Avatar
so what about the stage 5 .48 is it worth a damn??
im just looking for something thats not gonna take 15 minutes to spool a turbo, i should probably save and buy a BB turbo!!!
Old Apr 24, 2005 | 10:01 AM
CASH's Avatar
i have the .63 housing on my turbo at the moment. Currently i am runninh 10psi. it goes to like 1psi at about 3500 then just jumps to 9psi at about 5000. note however this is a d15b. Would it make more sense for me to try and get a turbonetics .48 housing to build power faster? I am going to be running about 15-17 psi daily as soon as i hit the Dyno. (note: the block is built)
Old Apr 24, 2005 | 12:09 PM
mrbsponge's Avatar
thats pretty much my question too!
i know that all my frineds with built D series run the .48 just in different stages, and i understand that the larger the AR is for higher revving and engines that have more exhaust flow, and pressure.
im just wondering if a B16 which is still 81mm could use a .48 but in a different stage like a 3 or a 5.
i would switch to a .48 on a sohc
Old Apr 24, 2005 | 02:54 PM
mrbsponge's Avatar
ttt
Old Apr 24, 2005 | 07:50 PM
CASH's Avatar
to be honest i dont mind building power a bit later because when it actually comes in the car feels very good. the other day i was on the road with a friend we both pulled up at the light together. He drives an evo 3 RS. he did have the launch but when the boost kicked in with my car the race was locked. i am guessing the smaller back housing would move the power band more into the rpm range which would make more sense... i am not the expert so someone else can share their info...
linx
Nov 12, 2008 09:47 AM
austrian type-R
Aug 8, 2003 12:53 AM
Greyout
Aug 7, 2003 08:15 AM
MatT3T4
Jan 26, 2003 07:52 AM
*Boostwerks*
Dec 21, 2002 07:10 AM
