Fuel Injection Air (FIA) Control Solenoid Valve F22B1 OBD1 HELP! PICS
Old Apr 22, 2005 | 11:00 AM
Stoich EG2's Avatar
Default Fuel Injection Air (FIA) Control Solenoid Valve F22B1 OBD1 HELP! PICS
okay, so i swapped out my H22A and put in an F22B1. Before i had a F22B2 so the wiring was different for the F22B1. There is no Fuel Injection Air Control Solenoid Valve on the F22B2 so i don't know where to plug it in! Does anyone know the pin outs for POA ECU?
another question, my idle is really low (under 500rpm) when i start it cold, then it dies. what could be the problem. i set the wax screw (fast idle valve?) all the way in, is it supposed to be out?
any help is appreciated. thanks all. here's some pics of vacuum diagram and my engine bay
Old Apr 22, 2005 | 11:25 AM
philadd's Avatar
Default Re: Fuel Injection Air (FIA) Control Solenoid Valve F22B1 OBD1 HELP! PICS (Advan06)
I can't help you with the pin outs, but...
Start adjusting the screw you mentioned to adjust your idle speed. It shouldn't be screwed in all the way... Just back it out some until the idle is normal again.
Old Apr 22, 2005 | 12:52 PM
Stoich EG2's Avatar
Default Re: Fuel Injection Air (philadd)
i adjusted it, and idle went up to about 2k then dropped back down to NOTHING! im fucken frustrated as **** right now and i want to drop an anvil on my fucken car...
95gsr@530
May 13, 2019 10:43 AM
troyport
Classic Hondas
May 28, 2009 09:06 AM
Thatssojdm
Aug 3, 2008 08:29 PM
geldingmakr
Aug 4, 2004 09:11 AM
prelude7342
Nov 5, 2003 04:38 PM
