Welding Charge piping good or bad?
well i bought a set of charge piping for my civic. i was wondering if i weld the pipes together, is that a good idea or a bad idea. i mean i have hoses to connect them. i just thought welding would be a better idea, because i've heard under high boost they would blow apart.
welding is ideal.. but sometime of course it wont fit w/o using a coupler or two.
You can easily weld a bead or put a couple tab nipples on the end of the pipe to prevent it from blowing off.
I have also heard you can spray a lil hair spray and it'll stick like glue. I painted my charge pipes and I think the paint acted the same way.
I'm down in Champaign too for school. Hit me up if you need car help.
depends on how its built. I did my charge pipes in 2 total pieces. One big piece for the intake side, and one seperate piece for the turbo side.
The way we designed it it came off rather easily when I wanted it off. But never blew off . We made beads around them too .
I never had a prob with pipes blowing off even with drag piping. I have never ever used a Tbolt clamp either. Only the cheap Advanced Auto ones.
Nothing wrong with welding the pipes, and for the sections that have to have a coupler weld a nut to the pipes on both ends and run a metal stap to insure they don't blow apart.
you can weld them. i have 1 weld on my pipes currently and its fine (see pic below). silicone will work too, and it can allow for some small tweaks in fitment. either way will work...
2000GSRT
Jun 13, 2003 01:46 PM
