Aluminized Steel Piping?
Old May 23, 2004 | 09:44 AM
RyanEJ8's Avatar
Default Aluminized Steel Piping?
I am going to be using aluminized steel piping for my intercooler/charge pipes from JC Whitney. I'll be following the directions for the piping from here. http://www.cse.uconn.edu/~yele....html
Since I don't want to have to use 9 silicon hose connectors, I will be having some of it welded together. Won't the aluminum coating blow off near the welds and then rust?
Old May 23, 2004 | 09:49 AM
HXMan's Avatar
Default Re: Aluminized Steel Piping? (RyanCivic2000)
I hope not. Half of my piping is going to be aluminized.
Old May 23, 2004 | 10:17 AM
dennis's Avatar
It'll be fine - not the lightest and most rust resistant, but it's fine. The welds will probabably rust long before the piping anyway. My buddy painted his and all is fine.
Old May 23, 2004 | 10:24 AM
Rod.'s Avatar
Default Re: Aluminized Steel Piping? (HXMan)
that is a good site. I saved that to my notes
Old May 23, 2004 | 01:10 PM
RyanEJ8's Avatar
Default Re: Aluminized Steel Piping? (dennis)
I guess I might just paint it, although I like the steel color. Maybe I can find a good high temp paint similar to it.
Old May 23, 2004 | 04:15 PM
pip9's Avatar
Definitely paint it. I've had mine on for a month or two and the welds are already starting to rust. The piping is good though.
Old May 23, 2004 | 04:32 PM
pornstarSR's Avatar
Default Re: Aluminized Steel Piping? (pip9)
yeah i used the aluminized piping from jc whitney...
eventually it will rust... theres nothing you can do about that..
paint it silver and it will still look metal like
Old May 24, 2004 | 08:41 AM
sky88's Avatar
why u guys dont use an aluminium pipe instead of aluminized steel piping
Old May 24, 2004 | 08:44 AM
RyanEJ8's Avatar
Default Re: Aluminized Steel Piping? (sky88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky88 &raquo;</TD></TR><TR><TD CLASS="quote">why u guys dont use an aluminium pipe instead of aluminized steel piping</TD></TR></TABLE>
Aluminized steel is cheaper and easier to work with (cheaper to weld).
Old May 24, 2004 | 08:54 AM
B18Flip's Avatar
if you dont want the welds to rust, just use stainless 308 MIG wire....works for me lol
Old May 24, 2004 | 09:13 AM
RyanEJ8's Avatar
Default Re: Aluminized Steel Piping? (B18Flip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">if you dont want the welds to rust, just use stainless 308 MIG wire....works for me lol</TD></TR></TABLE>
I don't have a MIG welder, but I'll keep that in mind wherever I take the piping to be welded. Thanks.
Old May 25, 2004 | 09:48 AM
sky88's Avatar
in malaysia a 20 feet of 2' aluminium is about 30-45 usd plus the work is about 30-50 completed,isn't it better to use aluminium?
Old May 25, 2004 | 10:08 AM
dennis's Avatar
I'd use aluminum if I had the right equipment, but I have a mig (w/o a spool gun for AL) at my disposal. So I just use what I have. I drive an accord anyway, it's not like I'm too concerned about weight
Old May 25, 2004 | 11:32 AM
quikB18B's Avatar
I m using the same stuff, I had Tony1 weld mine in a couple places to keep the couplers to a minimum, then I painted it with some 500vht stuff from Walmart and it looks fine.
zcrx2006
Sep 30, 2007 03:31 PM
376R
Apr 22, 2005 09:21 AM
redboost10
Oct 28, 2003 07:08 PM
Snafu-Si
Feb 12, 2003 12:27 PM
DigitalFusion
Jun 22, 2002 02:04 PM
