b16 issues
Old Apr 21, 2005 | 04:14 PM
ajzeg's Avatar
Default b16 issues
i have a b16 built bottom end built meaning:
-B16A SiRII OBD1 block, honed and hot tanked
-JE 12.5:1 pistons with JE rings file cut for all motor
-Machined B16 rods to accept JE press fit wrist pins, magnafluxed/shotpeened
-OEM Honda "pink" main bearings for loose tolerances=more HP
-OEM Honda "green" rod bearings
-the head is stock for now
-uberdata ecu
PROBLEM:
The problem is the ****** thing doesnt run right(just kiddin)
When the car is in nuetral it revs fine past 3000 rpm's
Now when i drive it it falls on its face when i hit 3000 rpms
As soon as it is under a load it feels like it either loads up or runs out of gas
Old Apr 21, 2005 | 04:22 PM
butters's Avatar
Default Re: b16 issues (ajzeg)
have you tried a different ecu yet?
Old Apr 21, 2005 | 04:36 PM
ajzeg's Avatar
Default Re: b16 issues (butters)
yea we tried a stock one
Old Apr 22, 2005 | 06:26 AM
ajzeg's Avatar
bump
Old Apr 22, 2005 | 12:56 PM
ajzeg's Avatar
come on any other ideas
Old Apr 22, 2005 | 12:58 PM
ironlung78's Avatar
fuel pressure?
do you have a gauge or have you checked it?
Old Apr 22, 2005 | 06:31 PM
ajzeg's Avatar
Default Re: b16 issues (sidesi)
i have not checked it
Old Apr 27, 2005 | 01:27 PM
ajzeg's Avatar
it was the wrong cap on the fuel rail and the one that was on there had a 3rd washer jammed down over the holes,
Old Apr 27, 2005 | 01:48 PM
spectacle's Avatar
glad you found the problem...how does it run?
90 integra DA9
Oct 29, 2009 02:00 PM
myke
51
Jan 26, 2006 11:16 PM
ajzeg
Apr 27, 2005 01:26 PM
Double_Clutchin
Apr 23, 2005 05:10 PM
99civ
Oct 28, 2004 08:43 PM
