b16 issues
b16 issues
i have a b16 built bottom end built meaning:
-B16A SiRII OBD1 block, honed and hot tanked
-JE 12.5:1 pistons with JE rings file cut for all motor
-Machined B16 rods to accept JE press fit wrist pins, magnafluxed/shotpeened
-OEM Honda "pink" main bearings for loose tolerances=more HP
-OEM Honda "green" rod bearings
-the head is stock for now
-uberdata ecu
PROBLEM:
The problem is the ****** thing doesnt run right(just kiddin)
When the car is in nuetral it revs fine past 3000 rpm's
Now when i drive it it falls on its face when i hit 3000 rpms
As soon as it is under a load it feels like it either loads up or runs out of gas
-uberdata ecu
PROBLEM:
myke
51
01-26-2006 11:16 PM
