wastegate hits hood
Old Apr 20, 2005 | 08:35 PM
Lmgrcivic's Avatar
Default wastegate hits hood
alright heres my set up I got a 94 EG coupe with B18B with a Rev hard manifold and a tial 38 mm wastegate and a VIS carbon fiber hood but when I go to shut my hood the wastegates hits the hood and it needs about .5 of in to shut any body know any thing about this or have the same problem thanks
Old Apr 20, 2005 | 08:45 PM
B18Flip's Avatar
Default Re: wastegate hits hood (Lmgrcivic)
you'll need to get a wastegate elbow
Old Apr 20, 2005 | 08:46 PM
Honda-Pilot's Avatar
I put some shims under the hood latch (hood side). I just used a couple washers and it worked fine. If you shim too much your hood will be too high for your quarter panels. Good luck.
Old Apr 20, 2005 | 08:48 PM
oxSLEEPERxo's Avatar
Default Re: wastegate hits hood (Honda-Pilot)
if you don't want to cut anything, get an elbow
Old Apr 21, 2005 | 02:32 PM
Lmgrcivic's Avatar
Default Re: wastegate hits hood (oxSLEEPERxo)
thanks guys for all the ideas
Old Apr 21, 2005 | 02:34 PM
dustin's Avatar
yep try this:
http://www.importparts.com/sho...b97dd
or cut the webbing in the hood
Old Apr 21, 2005 | 04:24 PM
kameleon23's Avatar
Default Re: wastegate hits hood (dustin)
I had the same problem with my Tial 38mm, and we just used a shorter nipple on the top of it...fixed
Old Apr 21, 2005 | 04:29 PM
Finland's Avatar
I also have the same gate, and had to cut off the hood reinforcement above the gate, I have a stock hood though.
Old Apr 21, 2005 | 05:42 PM
raceACCORDingly's Avatar
turbosmart ultragate wg rocks in these situations.
Old Apr 22, 2005 | 06:57 AM
powerls's Avatar
yep the Turbosmart Ultragate is smaller in height then the Tials. Plus it is a better wastegate anyway.
Old Apr 22, 2005 | 07:19 AM
Da K00l Aid Mayun's Avatar
Default Re: (powerls)
I had the same problem, so I just bought a Full Race manifold to fix that problem
Old Apr 22, 2005 | 09:53 AM
TRUST8383's Avatar
Default Re: (Da K00l Aid Mayun)
I have the same set up except w/ an inlinepro mani. I also have the VIS hood. The cheapest thing to do is get a brass 90 degree nipple to put on top. It sits lower than the bulky banjo one that comes w/ the tial. Then you take a dremel and just take a small notch out of the hood under skeleton/reinforcement. It doesn't take much trimming and it's easier than getting a new elbow/dump tube.
2004es2
Feb 27, 2009 12:51 PM
Lmgrcivic
Apr 21, 2005 02:31 PM
VtecAdil
Oct 14, 2004 10:44 AM
flarinpnoi
Apr 28, 2004 09:41 AM
92HB_HB
Aug 31, 2002 08:57 PM
