wastegate hits hood
Old Apr 20, 2005 | 08:34 PM
Lmgrcivic's Avatar
Default wastegate hits hood
alright heres my set up I got a 94 EG coupe with B18B with a Rev hard manifold and a tial 38 mm wastegate and a VIS carbon fiber hood but when I go to shut my hood the wastegates hits the hood and it needs about .5 of in to shut any body know any thing about this or have the same problem I also posted this in the forced induction section thanks
Old Apr 20, 2005 | 08:36 PM
IS3Fifty's Avatar
Default Re: wastegate hits hood (Lmgrcivic)
take a pic of where its making contact with the hood, I have an idea but it wont help if we can see it.
Old Apr 20, 2005 | 08:45 PM
SOHC4life 96's Avatar
Default Re: wastegate hits hood (Bar'dEK)
Cut that part of the skeleton off that is hitting it. Don't worry about it ******* up the hood. You should see my buddies VIS hood. He cut out out damn near the whole center skeleton and his still looks good (fitment wise), the top looks like *** cause the fucked it up with some crack fix.
Old Apr 20, 2005 | 08:53 PM
eg4usdm's Avatar
Default Re: wastegate hits hood (SOHC4life 96)
if you cut the skeleton out of the hood the extreme heat coming off that turbo will bubble and cause some discoloration and ugliness to the hood.....
at least thats what ive seen..
Old Apr 20, 2005 | 09:51 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: wastegate hits hood (eg4usdm)
when my b series valve cover hit the hood of my CRX, i used about 3 or 4 washers underneath the mounts to the engine, to lower the engine in the chassis a hair. you could try this, but the only draw back is you loose that much ground clearance from the oil pan, to ground.
Old Apr 21, 2005 | 02:31 PM
Lmgrcivic's Avatar
Default Re: wastegate hits hood (Built B16A)
thanks guys for all the ideas
BEAT_UP_EK
Jan 10, 2010 05:19 PM
2004es2
Feb 27, 2009 12:51 PM
Lmgrcivic
Apr 22, 2005 09:53 AM
pvt_awol
Nov 4, 2004 02:11 PM
GraphiteAccord
May 5, 2003 12:00 PM
