typeR swap
Old Apr 20, 2005 | 06:48 PM
99lsteg's Avatar
Default typeR swap
ok, I know this section is not for typeR's but I have a 99 LS and i just put in a 00 typeR engine. I have a few problems ... and any help is appreciated ... First ... i'm using the stock LS engine harness and the vtec is not working ... yes .. there is a clip that hooks up to the vtec from the stock ls harness but no go ... second i am running a p28 chipped with a skunk2 program but i'm getting a check engine light ... checked the code and it's a 21 "VTEC spool solenoid valve" so i'm guessing that once i take care of my vtec problem ... i won't have a check engine light anymore ... any suggestions on what to do to hook up my vtec to the LS engine harness ???? Once again ... any help is appreciated !!!
Old Apr 20, 2005 | 07:19 PM
Kendall's Avatar
Hardwire the solenoid to pin A4 on the ECU, end of story.
Old Apr 20, 2005 | 07:20 PM
99lsteg's Avatar
Default Re: (Kendall)
would that be the green and yellow wire ???
Old Apr 20, 2005 | 07:23 PM
Kendall's Avatar
I'm sure the link below will be of great assistance in finding the answer.
https://honda-tech.com/zerosearch
im_inn0c3nt
Engine Management and Tuning
11
Sep 2, 2009 12:15 PM
monkey_boi
Nov 8, 2008 11:30 PM
92hondaswap
Jul 5, 2008 03:33 PM
tegsallgood
Nov 4, 2004 04:56 AM
WalkEX99
Jan 23, 2003 04:48 AM
