oxygen sensor problems
Old Apr 20, 2005 | 03:46 PM
PuiPui's Avatar
Default oxygen sensor problems
b16a2 swaped into a 92 civic si hatch, using a chipped p28 and a obd2 gsr wiring harness
I got a code 1: primary o2 sensory code after the swap, and now i put in a new o2 sensor, and reset my ecu and i'm getting the same problem!
any ideas??
at the passenger side shock tower i have 3/4 plugs on the obd2 gsr engine harness plugged in, the 4th plug doesn't seem to connect to anything.
PLEASE HELP!
Old Apr 20, 2005 | 04:15 PM
civictildeath's Avatar
Default Re: oxygen sensor problems (PuiPui)
has the o2 sensor been wired wrong or did you replace without rewiring?? if so, the 2 wires of the same color could be backwards
Old Apr 25, 2005 | 10:12 PM
PuiPui's Avatar
Default Re: oxygen sensor problems (civictildeath)
its wired correctly, when i swapped engines the o2 sensor that came with it should have been fine, but i replaced it anyways because there was a CEL code 1.
now that i've changed it out, there is still a CEL
i am pretty sure i am running in safe mode right now
bad mileage and dumping fuel at higher rpms
Old Apr 25, 2005 | 11:52 PM
hatch34's Avatar
do you have the second O2 in your exhaust beccasue if you dont then that will throw a code also. and maybe you happend to get a bad "new" O2 maybe
Old Apr 26, 2005 | 12:37 AM
silentblackhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PuiPui &raquo;</TD></TR><TR><TD CLASS="quote">its wired correctly, when i swapped engines the o2 sensor that came with it should have been fine, </TD></TR></TABLE>
Did u use a universal oxygen sensor as the new one? if u did, on my civic the WHite wire was the signal and the green was the ground. THe universal Denso sensor i had, has a white and blue wire. i put the 2 white wires together and the green and blue ones together, seemed to make sense. I kept getting the code 1 error and bad gas mileage and everything till i figured out those needed to be switched. Maybe this will help, maybe it wont but good luck on ur project
Old Apr 27, 2005 | 11:01 PM
PuiPui's Avatar
Default Re: oxygen sensor problems (silentblackhat)
i bought a bosch one(#15733), but i guess it wont hurt to try again, i used the simple wiring diagram that i found on HT,
and wired it up that way
i read a post about some guy with the same bosch one as me and it had 2 white wires and a grey and a blue?
mine had 2 blacks, blue and white, and i wired it according to that digram any more suggestions?
I havn't seen the obd2 gsr engine harness used much on a bseries OBD2-&gt;1 swap before and i figured it'd give it a try, everything works cept this damn o2 sensor...
Also in reply to the guy above, I converted to OBD1, there is only one o2 sensor, what exhaust guys call 'upstream' or what i call Pre-cat (referring to primary o2)
Yajhershey
Feb 1, 2014 03:04 PM
vietnameseone
Jan 19, 2009 06:07 PM
.Hookedonhatch.
Dec 12, 2008 01:23 PM
sackdz
Nov 4, 2003 06:40 PM
VTC_CiViC
Apr 18, 2003 10:12 AM
