prob. with right corner and city light
Old Apr 20, 2005 | 03:32 PM
ItrpwrdCrx's Avatar
Default prob. with right corner and city light
My right side corner and city light in my 99 ek stopped workin last night...Checked the bulbs,fuses and wires, everything is good..The turn signal works.The left side is working fine.Any one know what could be wrong..
Old Apr 20, 2005 | 04:27 PM
ItrpwrdCrx's Avatar
n e 1?
Old Apr 20, 2005 | 06:54 PM
93Civac's Avatar
Default Re: (97JDMEKSLEEPER)
I have no clue bump
Old Apr 20, 2005 | 06:58 PM
idriveadelsol7's Avatar
Default Re: prob. with right corner and city light (97JDMEKSLEEPER)
i would help you out... but what are city lights? i always wanted to know...
Old Apr 20, 2005 | 07:09 PM
ItrpwrdCrx's Avatar
bump
Old Apr 21, 2005 | 04:29 PM
ItrpwrdCrx's Avatar
ttt
Old Apr 25, 2005 | 07:48 PM
ItrpwrdCrx's Avatar
bump
Old Apr 25, 2005 | 09:03 PM
nocturnaldragon's Avatar
Default Re: prob. with right corner and city light (deLasoL7)
I have no clue what hes referring to either. Perhaps his parking lights? other then that i dont know what hes talking about. But if the bulbs are good and the wiring is good. How did you check the wiring? Im assuming they go into your headlamp switch, perhaps there is something wrong with that or a relay that the wiring is going into. Continue to check the wireing untill your sure its good. Also check the grounds, a bad ground will still show up good on a test light or volt meter, but wont allow enough current to pass for a bulb to light up. Good luck and get back to me if you need more help.
Old Apr 25, 2005 | 09:36 PM
t0ekn3e's Avatar
wierd bump for you
Old Apr 26, 2005 | 02:44 PM
dumpedeg6's Avatar
check the ground wire, make sure its not exposed...i had that problem on my city lights
Old Apr 26, 2005 | 03:42 PM
ItrpwrdCrx's Avatar
wheres the relay located?
eagarcia88
Honda Civic (2001 - 2005)
Apr 18, 2011 06:05 PM
dc2driver408
Aug 15, 2010 07:03 PM
wilaivue
Dec 1, 2008 06:20 PM
phoshizzle88
Sep 16, 2007 05:59 PM
RedHackBatch
Jul 6, 2004 09:39 PM
