Trying to build a manifold...need advice!!
Old Apr 19, 2005 | 03:55 PM
JMcDB18C's Avatar
Default Trying to build a manifold...need advice!!
Hey guys Im thinking about buying these pieces from ths guy he is selling 304L SS 90 bends and 45's and they are 16 gauge, is that going to be thick enuff for high boost...?????All info greatly appreciated. Thanks. heres the link of the manifold i want to duplicate.
http://www.we-todd-did-racing....D.jpg
Old Apr 19, 2005 | 09:19 PM
Just Checking In's Avatar
Default Re: Trying to build a manifold...need advice!! (JMcDB18C)
16 guage steel is a bit thin for exhaust manifold runners.
Old Apr 19, 2005 | 09:56 PM
Ekasey's Avatar
Default Re: Trying to build a manifold...need advice!! (Just Checking In)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Just Checking In &raquo;</TD></TR><TR><TD CLASS="quote">16 guage steel is a bit thin for exhaust manifold runners.</TD></TR></TABLE>
16 g stainless 304 is not too thing while the optimal choice is a 321 i think that you can make 304 last as long proper header building technique is employed. You should also build a brace to take the load off the header, this way the ehader can grow and do what it needs and not crack
Old Apr 20, 2005 | 03:25 AM
Engloid's Avatar
OG Fabricator
You may have problems duplicating that in the space you have in the car. Make sure to check the radius of the bends. I'd bet money that the bends you're considering out of tubing will not turn as sharp of a radius as the pipe fittings in the pic of the manifold you're wanting to duplicate.
Rayz_Si
27
Dec 26, 2006 09:00 PM
Keyhole
Welding / Fabrication
12
Aug 31, 2005 05:15 AM
04falcon
Dec 19, 2004 03:24 PM
.dave
10
Dec 10, 2004 07:49 PM
turbotypeR@SPEC
Dec 10, 2003 04:03 AM
