SOHC Vtec engines.... how many are there?
I always thought there was only one, being the D15b. Then I remember the D16z6, here: http://tech.hybridgarage.com/tech/specs.htm. Whats the deal? The D15b was only available in Japan, correct? Are these the same engines, are my sources incorrect?
Also, a friend of mine is claiming that he has a 95 Civic EX motor (so I'm guessing D16z6) using a B16 ecu. He says the car runs perfectly, and that everyone who does SOHC Vtec buildups use the B16 ECU and it works fine. I said bullshit, your timing/fuel maps would be fucked, vtec crossover would be fucked, the car might run but would run like ***. He says its not the case, and that the motor redlines at 8 grand, and vtec crosses over at 4700rpm. I know most of the stuff he is saying is bullshit, but can anyone provide me some solid proof? I'm just going on what I think should be happening.
He says its from a b16, but from the sound of it, I doubt dude even knows ECU codes. Sounds like a typical ricer to me, and I want technical info to shut him up good.
Ah well its not for me, I have a friend saying that he has a d16z6 (I'm guessing) with a b16 ecu in it. Whether or not he has it chipped I don't know, as it would make more sense just to get a proper d-series ecu.
dont forget the underdog motor! ZC! zc's came in dohc non vtec, sohc non-vtec, and sohc vtec obd-1. all vtec ecus are compatible, but might not best suit the engine it is controlling. it is possible to chip them with different maps. for instance i have non vtec dohc ZC with a non vtec 89 integra ecu. it has more agressive fuel and timing maps than the stock crx si ecu and a higher rev limit. you would have to dyno to be sure but im guessing that the B16 ecu gives a bit more umph than any D-series. just my .02
b16 maps are a total misfit for almost any sohc setup...there is a slim margin of moderately built sohc where it would be 'ok'.
the most common sohc vtecs are-
d16z6
d15b vtec
sohc zc vtec
d16y8
and a miriad of economy-minded d15 vtecs
There are strange variants of the assorted engines, like d16z2, d16z9, etc, but they are few are far between so who cares.
d16z6
d15b vtec
sohc zc vtec
d16y8
