! HELP ! VTEC PROBLEM !
Old 12-07-2009, 11:51 AM
mario_a_05's Avatar
Default ! HELP ! VTEC PROBLEM !
I have a sohc vtec motor, but the vtec does not engage. I have correct wiring. But I do have an oil leak. Could loss of oil pressure disable VTEC from working? Or can it be the solenoid? Im running an ecu chiiped for a b16 dont know if thats the problem. any advice? thanks.
Old 12-07-2009, 11:55 AM
90Rexx's Avatar
Default Re: ! HELP ! VTEC PROBLEM !
wow... lol....
use the correct ecu.... then check for codes... go from there
or u can just fill up the vtec fluid and install a vtec solenoid cover. lol
oh and how do u know vtec doesnt engage? it is an SOHC.... not very easy to tell
Old 12-07-2009, 11:58 AM
mario_a_05's Avatar
Well VTEC use to crack and it was pretty loud for a sohc lol...I was using a gsr ecu and it cracked at 4500...But then all of sudden it just quit on me...
Old 12-07-2009, 01:18 PM
Technical Hero
HondaPartsHero's Avatar
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old 12-07-2009, 06:41 PM
redline7070's Avatar
gsr and b16 use knock seneors and d16 do not so use a p28 ecu
Old 12-08-2009, 12:48 AM
got00rice's Avatar
i used to own a d16z6 and you can actually hear the change over when vtec engage..so dont under estimate the single cam...
obuhmyuh
30
12-21-2007 12:10 PM
k20rex
15
02-26-2006 10:09 AM
master honda tech
08-19-2004 07:17 AM
1ntensiveVTECivic
11-22-2003 10:33 PM
vspec12
11-05-2001 05:25 AM
Quick Reply: ! HELP ! VTEC PROBLEM !
