Gtech on a turbo d16z6....help with results.
Old Apr 19, 2005 | 09:57 AM
Cee_mon's Avatar
Default Gtech on a turbo d16z6....help with results.
Hey guys, some of you might think its that accurate but i have seen it come within .1 sec alot at the track in my buddies car. Anyways I ran acouple runs on the turbo d16z6 today. I was hitting 7psi until around 6Krpm where it starts to drop down to 5.5-6psi. Anyways here are the results, please state what if any number seem off to you guys. GTECH dyno graph at bottom.
60ft----2.345
1/8th--9.709 @77.34mph
1/4----14.825 @ 96.78mph
60 ft----2.323
1/8th--9.670 @ 76.90mph
1/4----14.864 @ 94.68mph
60ft ----2.329
1/8th-- 9.624 @ 77.59mph
1/4 ----14.756 @ 96.40mph
Quick breakdown of the car....
95 coupe with d16z6
greddy kit @ 7psi drops to 6psi of so after 6K
drag fmic
AFC hack
2.5in exhuast, highflow cat to magnaflow
bully clutch / 9lb flywheel
Falken azenis set at 38psi on 14in wheels
Dont mind the info in the top left corner as you dont launch and only run 1 gear about 3K rpm. This graph was done in 3rd gear. Notice the power level out around 6K when boost starts to drop. Also what HP increase do you guys think should be there if i get to hold 7psi to redline?
If anymore info is needed, post up and i will respond.
Thanks
Old Apr 19, 2005 | 09:59 AM
Muckman's Avatar
Moderator in Chief
Default Re: Gtech on a turbo d16z6....help with results. (Cee_mon)
Gtechpro RR I got one too
Old Apr 19, 2005 | 11:34 AM
yellowturbo's Avatar
hey a gtec look pretty accurate thats cool... well I would not tune with a gtec but its cool to give you an idea !
Old Apr 19, 2005 | 01:02 PM
Cee_mon's Avatar
Default Re: (yellowturbo)
Any ideas on what I could get with that trap?
Old Apr 19, 2005 | 01:27 PM
Muckman's Avatar
Moderator in Chief
Default Re: (Cee_mon)
~14.4 if you could get the 60' down to 2.1
Old Apr 19, 2005 | 01:39 PM
igo4bmx's Avatar
which gtech did you use?
i saw this on ebay for cheap
http://cgi.ebay.com/ebaymotors...46100
Old Apr 19, 2005 | 01:42 PM
SOHC_MShue's Avatar
looks about right for your setup. Wow I may have to get one of those gtech things
Old Apr 19, 2005 | 04:09 PM
Cee_mon's Avatar
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">which gtech did you use?
http://cgi.ebay.com/ebaymotors...46100</TD></TR></TABLE>
I used the one of the older models the Gtech Pro Competition. I was alittle disappointed to see the psi drop off near redline. I will be pressure testing the piping in the next few days. I just hope the older TD04H-15C doesnt just die out on me in top end.
Also iam using a profec B 1st model, i have the balance set of full and run off only the low boost setting for now. Should i try and run 7psi on highboost, or will it make no difference? Also would the balance **** maybe help?
Old Apr 19, 2005 | 04:54 PM
kabaroo's Avatar
those 15G greddy kits are not top end monsters... But they spool by 3k!
jarvis199
Feb 1, 2007 09:56 AM
streetlvlhatch
Apr 22, 2004 06:33 AM
racinskittle
Oct 28, 2003 06:07 PM
93TurboSi
Sep 30, 2003 09:43 AM
bearboy80
Apr 24, 2003 09:20 AM
