clutch finally died?
Old Apr 18, 2005 | 11:54 PM
All Motor EH2's Avatar
Default clutch finally died?
I have a stock 92 vx hatch, it has 173,xxx miles on the odometer. Today I pulled into a parking lot and when I was turning in I let off the clutch, It made a really bad grinding sound, kinda sounded like something was rubbing against the car.
It only makes the sound when the RPMS are up and the clutch is NOT pressed in. I believe it's probably the throwout bearing. As I was driving home I shifted the car into 2nd and it popped out of the gear into neutral all by itself( I know it was a dumb idea to drive it home but I really can't afford a tow truck right now.) My clutch catches but it slips horribly.
I'm guessing it would most likely be in my best interest to just purchase a new clutch. If anyone knows a good place to get a clutch for my stock civic, please let me know. I don't need anything special as long as it's gonna last me at least another few months til I can get a swap.
Thanks
Modified by All Motor EH2 at 2:15 AM 4/19/2005
Old Apr 19, 2005 | 01:59 AM
Default Re: clutch finally died? (All Motor EH2)
up.
Old Apr 19, 2005 | 04:08 AM
Frozen E's Avatar
H-T White Ops
Buy an Exedy stock replac`ement clutch and have a local shop drop it on for you. You can find them on ebay for $100 for the stage 1's and then couple hours of labor at a trann shop. So about $250 you'll be rolling again.
Old Apr 19, 2005 | 12:59 PM
Default Re: (IslandSi)
Is installing a clutch extremely difficult? I would really rather do it myself with the help of a couple friends or something. Not just to save money, but as a learning experience really.
Thanks for the reply.
Old Apr 19, 2005 | 01:35 PM
Frozen E's Avatar
H-T White Ops
not difficult at all if you have the right tools. You'll need a couple of 12 pt. sockets. I think an 8mm and an 18. Not quite sure on that though. Do some searching around on here.
Other than that, once you get the flywheel out you'll want to have a shop resurface it judging by how you explained your current clutch situation.
Old Apr 19, 2005 | 01:46 PM
civic-si-2000's Avatar
Go for it why pay someone 150$ when you can do it for free. I did mine in a friends garage. In an out with floor jacks. Its not that hard just nuts and bolts
Old Apr 19, 2005 | 01:49 PM
jbscivichb92's Avatar
Default Re: (civic-si-2000)
it isn't very hard to change out a clutch. if your car is popping out of gear you might be low on tranny fluid.
Old Apr 19, 2005 | 02:21 PM
Default Re: (jbscivichb92)
Thanks.
Old Apr 19, 2005 | 02:53 PM
Anyone know where I can get a clutch from? I'll look on ebay, but I'd really like to shop around a little.
Thanks.
- Nick
Old Apr 19, 2005 | 03:26 PM
t0ekn3e's Avatar
i picked up a clucth off craigslist i think theres another one for sale on there
Old Apr 19, 2005 | 03:38 PM
mattssi's Avatar
if your car is popping out of gear, then it is most likely the tranny(fluid) If you cannot get it into gear or out, then look at your clutch.
Old Apr 19, 2005 | 03:47 PM
Deemeetree's Avatar
Electrician
http://www.clutchcityonline.com
Old Apr 19, 2005 | 06:23 PM
biotech0123's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-si-2000 &raquo;</TD></TR><TR><TD CLASS="quote">Go for it why pay someone 150$ when you can do it for free. I did mine in a friends garage. In an out with floor jacks. Its not that hard just nuts and bolts </TD></TR></TABLE>
Very true
Old Apr 29, 2005 | 08:21 PM
civic_tuned's Avatar
if u know what your doing. why not pay the 150.00 and get it installed by a professional and get it done right. if it messed up or just something is not working just working properly take it back. $250.00 is not think of it as an investment and it will lower your times! Also its all about warranty! ask your self this do your friend have warranty?
Old Apr 29, 2005 | 09:14 PM
Otherguy's Avatar
NASIOC.com
Default Re: (civic_type_r)
its a 10mm 12 point and a 17mm 12 point...
pencilface
Nov 25, 2013 04:47 PM
tehbrosta
10
Jan 14, 2007 05:43 PM
mr abstract
Nov 27, 2006 10:56 AM
turnsignalandy
14
Aug 22, 2006 07:13 AM
neopheus
Mar 13, 2005 10:20 PM
