tranny stumped
Old Apr 18, 2005 | 04:51 PM
tallguy's Avatar
Default tranny stumped
I posted this in the integra forum and im just seeing if any one here can help.
https://honda-tech.com/zerothread?id=1217469
Old Apr 18, 2005 | 05:17 PM
ServiceAdvisor's Avatar
https://honda-tech.com/zerothread?id=596873
Make sure all your bearings are flush, and the mainshaft/countershaft are not missing the case. They tend to flex with minimul effort. Also, make sure the differential is flush and input shaft bearing isn't toast. The trick I used was to shake the outter case a bit until the shafts slid into place, then tighten down the corner bolts a bit to put pressure on the C clip, then seperated it with a snap ring plier. - Darrell
sanman000719
Transmission & Drivetrain
Feb 7, 2010 04:34 PM
Lmgrcivic
Oct 10, 2005 07:43 AM
ultimatehonda
Apr 30, 2004 08:03 AM
ultimatehonda
Apr 29, 2004 07:28 AM
integra95
Jun 30, 2003 05:32 AM
