no power after 3000 rpm
Old Apr 18, 2005 | 03:51 AM
EKB18BPR3's Avatar
Default no power after 3000 rpm
i have a b18b1 turbo and recently built the motor. well after the build i started her up and i had no power after 3000 rpm. the car just dies. also when i shift, the car acts as if its not getting gas and hesitates. i know some of u had the same problem but i couldnt find it in search. so let me know how u fixed it. thanx.
Old Apr 18, 2005 | 04:01 AM
beavis's Avatar
Default Re: no power after 3000 rpm (98B00STED)
sounds like distributor problems to me. check that
Old Apr 18, 2005 | 07:53 AM
95lstegman's Avatar
Default Re: no power after 3000 rpm (Black95gsr)
could be as simple as ignition timing set incorrectly. it's supposed to be 16 degrees before top dead center.
Old Apr 18, 2005 | 05:55 PM
EKB18BPR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black95gsr &raquo;</TD></TR><TR><TD CLASS="quote">sounds like distributor problems to me. check that </TD></TR></TABLE>
what do i check in the distributor? would my map or TPS sensor cause it to loose power too?
Old Apr 18, 2005 | 06:51 PM
eag36's Avatar
another guy on here just had a similar problem, turned out to be a clogged exhaust pipe... do a quick check for that.
Old Apr 19, 2005 | 03:47 AM
EKB18BPR3's Avatar
Default Re: no power after 3000 rpm (eag36)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eag36 &raquo;</TD></TR><TR><TD CLASS="quote">another guy on here just had a similar problem, turned out to be a clogged exhaust pipe... do a quick check for that.</TD></TR></TABLE>
i have an opened pipe actually
robbys89
10
May 8, 2009 08:30 AM
skata89
Oct 23, 2007 10:09 AM
Circuit Star-29
May 19, 2006 10:16 AM
stockegsix
Jul 28, 2005 06:16 AM
the-pepsi-man
Jan 25, 2005 08:13 PM
