Loss in power from 3500-4000rpm? any ideas?
94 b16a coupe. this is a new 1 too me. when driving and hit 3500 their is a loss in power up till 4000 4500rpm. you can feel a slight hold back like you just applied the hand brake and it dosent increase speed and rpm as fast as it normaly would. used to do it at 3000-3500rpm somtimes but now its doing it almost all the time. replaced spark plugs, rotor, leads,icm serviced not too long ago along with fuel filter. going on bout 3 weeks now???
Re: Loss in power from 3500-4000rpm? any ideas?
no havent done that. no cel lights. all i can do is check connections right? can they be cleaned or anything?
the distributor cap is verly new. got it 3-4 months ago. i did once have a problem starting the car and i replaced the ICM along with the sensors from a sohc distributor (same internals) but in the end i was just me mixing up 3 and 4 spark leads but the car ran fine for say 3-4 months after then out of the blue this start happining
check and see if your dizzy wiring is tight in the dizzy plugs and see if the screw that holds the rotor in didn't back.
If it were me I'd check the cheap stuff first. Have you checked the fuel filter? My friend had a similar problem with his. Thought I'd just throw that in there.
thanks for all the help guys. i got the car goin much better now. the ignition timing was a bit off so i had to advance it
