wobbling wheel
i have a 90 integra rs, and the rear passenger side wheel is wobbling when i drive, my friend was driving behind me today and told me, so i tryed taking the wheel off and putting it back on but it still wobbles, so yea is there a certain way to check of the lca is bent or whatever is causing it to wobble? need help asap thanks
Check the wheel bearing. Jack the bad corner up and try and wiggle your wheel back and forth. If there's play ? Odds are you need a new wheel bearing (unless your lugs are loose).
Also, slalom left to right at about 20-30 mph, when the weight shifts to the bad corner, if it's bad, you should hear and feel the vibration (if it's the wheel bearing).
its not the wheel bearing becuase i don't hear the viberation comnig from it also i forgot to mention my car was stolen and they left it on the ground without any wheels is that maybe why its bent?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznxlunatik »</TD></TR><TR><TD CLASS="quote"> also i forgot to mention my car was stolen and they left it on the ground without any wheels is that maybe why its bent?</TD></TR></TABLE>
i would say deeeefinitely that is why.
bump for your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jh4dC4# »</TD></TR><TR><TD CLASS="quote">might be the tire</TD></TR></TABLE>
could be. I had a bad wobble on my accord and it turned out that both my rear tires had bulged.
