P28 ecu?
Old Apr 17, 2005 | 01:24 PM
civiccoupe94's Avatar
Default P28 ecu?
im running a dx motor, all stock with intake. a friend of mines has a extra P28 and can lend me it to play around with for a bit or so. im more of a saving gas kind of person, since gas prices are so high, but he says its going to give my b7 more power because i can rev higher without hitting rev limiter earlier with the P28.
will the P28 waste more gas on normal driving? or will it only waste more gas on the high rpms because of the rev limiter setting at a higher rpm? thanks..
oh yea i get about 37 mpg with some hard acceleration once in a while
Old Apr 17, 2005 | 01:26 PM
jlacoy82's Avatar
71.192.16.183
Default Re: P28 ecu? (civiccoupe94)
You're friend is an idiot. Use your stock ECU and leave it at that.
If you want to use fuel maps that ARENT for your car and rev your car higher than it was designed to and possibly destroy your head/valvetrain/pistons, then using that p28 is an awesome idea.
Old Apr 17, 2005 | 01:57 PM
ZacCarter's Avatar
What he said^
Old Apr 17, 2005 | 07:27 PM
hatchi's Avatar
not to mention a CEL
Old Apr 18, 2005 | 04:16 AM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default Re: P28 ecu? (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">You're friend is an idiot. Use your stock ECU and leave it at that.
If you want to use fuel maps that ARENT for your car and rev your car higher than it was designed to and possibly destroy your head/valvetrain/pistons, then using that p28 is an awesome idea.</TD></TR></TABLE>
Syndacate
14
Mar 13, 2020 01:59 PM
blackbndt
12
Sep 23, 2009 06:53 PM
bullock
Aug 19, 2004 08:14 AM
Vic Nyce
Apr 3, 2003 03:42 PM
