rough idle, code 3/9
Old Apr 17, 2005 | 10:57 AM
boostmywankle's Avatar
Default rough idle, code 3/9
hey, i got a 92 cx converted to pre obd with a 1st gen b16a...I'm throwing code 3 (map sensor) and code 9 (cylinder sensor)... i have a new distro. coming, because the one that is on it looks ot be like a b17 one...kinda riggeed up.. my car is running like ****...it has a boucy idle from 600 down to maybe 150rpms it does it non stop.... also i belive vtec inst engaging...would the map sensor and distrobutor do this to my car!?
Old Apr 17, 2005 | 04:04 PM
Default Re: rough idle, code 3/9 (96teggyls)
anyone????
Old Apr 17, 2005 | 04:20 PM
komat's Avatar
vtec wont work with a cel
thats all i care tell you sorry
Old Apr 17, 2005 | 04:24 PM
Default Re: rough idle, code 3/9 (komat)
are you sure... i had vtec in my old gsr when i through a code for 02 sensor!?
Old Apr 17, 2005 | 04:30 PM
komat's Avatar
from what i keep reading from other post
im pretty sure if u have any cel vtec will not work
but i could be wrong it could be just certain ones
Old Apr 17, 2005 | 04:41 PM
thanks....anyone else???
Old Apr 18, 2005 | 03:56 AM
someone musttttt know soemthingggg
Old Apr 19, 2005 | 07:11 AM
ttt
Old Apr 19, 2005 | 07:14 AM
e jay one's Avatar
why did you down grade to obd0? sounds like you got a ghetto rigged set up. and im pretty sure if your getting a code for cylinder sensor your not gonna be able to use vtec. just my 2 cents.
Old Apr 19, 2005 | 07:15 AM
Default Re: rough idle, code 3/9 (e jay one)
haha i bought the car this way, im planning on running obd1 soon! too bad i sold my gsr ecu and harness before i got the car
Old Apr 19, 2005 | 07:20 AM
e jay one's Avatar
what ecu is in it? did you check to see if the previous owner even hooked up the vtec sylonoid right? i hope you got a steal on this car.
Old Apr 19, 2005 | 04:41 PM
it has a pr3 ecu, i got the vtec problem figured out, replaced map! but now, i got a new obd0 b16a distro. from distributorking.com and it wont fire up....i think it had a obdo teg distro in the first place...it will only run with the teg one, whats up with that??
FASTESTCB7inQNZ
Nov 18, 2009 06:41 AM
WickedWerx
Oct 28, 2004 07:02 PM
Achenar
Oct 2, 2004 01:45 PM
Gant
Sep 19, 2004 09:37 PM
synergy004
Jul 6, 2001 11:45 AM
