rough idle, code 3/9
hey, i got a 92 cx converted to pre obd with a 1st gen b16a...I'm throwing code 3 (map sensor) and code 9 (cylinder sensor)... i have a new distro. coming, because the one that is on it looks ot be like a b17 one...kinda riggeed up.. my car is running like ****...it has a boucy idle from 600 down to maybe 150rpms it does it non stop.... also i belive vtec inst engaging...would the map sensor and distrobutor do this to my car!?
Re: rough idle, code 3/9 (96teggyls)
from what i keep reading from other post
im pretty sure if u have any cel vtec will not work
but i could be wrong it could be just certain ones
why did you down grade to obd0? sounds like you got a ghetto rigged set up. and im pretty sure if your getting a code for cylinder sensor your not gonna be able to use vtec. just my 2 cents.
Re: rough idle, code 3/9 (e jay one)
haha i bought the car this way, im planning on running obd1 soon! too bad i sold my gsr ecu and harness before i got the car
it has a pr3 ecu, i got the vtec problem figured out, replaced map! but now, i got a new obd0 b16a distro. from distributorking.com and it wont fire up....i think it had a obdo teg distro in the first place...it will only run with the teg one, whats up with that??
WickedWerx
10-28-2004 07:02 PM
Achenar
10-02-2004 01:45 PM
Gant
09-19-2004 09:37 PM
