CTR pistons w/ Type R rods?
Old Apr 17, 2005 | 09:15 AM
xonefastackx's Avatar
Default CTR pistons w/ Type R rods?
I've got a Type R with Skunk 2 Stage 2 cams, plus all the other natural upgrades that come with these, as well as hondata. I'm looking to up the compression on it a bit by putting ctr pistons. I know that they wont fit other rods, but I'm not sure if civic r pistons will fit integra r rods. If they do, then i'm assuming the bore will be right as well? Thanks for your help.
Old Apr 17, 2005 | 09:16 AM
chad's Avatar
Moderator
Default Re: CTR pistons w/ Type R rods? (xonefastackx)
slap them on (well heat and press them)
have done this about 50 times
Old Apr 17, 2005 | 09:17 AM
RTW DC2R's Avatar
They fit ITR rods fine. You would probably be better off getting the oversized CTR pistons and boring the cylinders so there arent any ring sealing issues, plus a bit more displacement.
Old Apr 17, 2005 | 04:24 PM
oh what are the oversized ctr piston sizes and what would i bore the block to?
Old Apr 17, 2005 | 05:00 PM
BlueR's Avatar
Default Re: (xonefastackx)
stock ctr piston=81.00mm
oversize ctr piston = 81.25mm
Old Apr 17, 2005 | 05:05 PM
ok, so if i took my oversized ctr pistons to any machine shop and said do what you have to get the rings to seal right they should have no problem correct?
Old Apr 17, 2005 | 05:06 PM
BlueR's Avatar
edit- well you have to them that your piston is 81.25 mm
Old Apr 17, 2005 | 05:09 PM
lol ok thanks, sorry for so many specific little questions, but i dont want to attempt to do it myself and i want to make sure on everything i'd have to do before i purchase them.
Old Apr 21, 2005 | 12:36 PM
Almost's Avatar
I've got CTR overbore pistons for sale....used for only 1000 km
Old Apr 21, 2005 | 01:11 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xonefastackx &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking to up the compression on it a bit by putting ctr pistons.</TD></TR></TABLE>
Just also be aware that CTR pistons in an otherwise "stock" (meaning no modifications that would affect compression) ITR motor will raise the compression ratio more than "a bit".
Old Apr 23, 2005 | 12:42 PM
Default Re: CTR pistons w/ Type R rods? (Padawan)
lol yea i'm looking to manage about 12.3:1 with those and a 2 layer headgasket, so it is probably a little more than a bit, but thanks for looking out
Old Apr 23, 2005 | 02:57 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xonefastackx &raquo;</TD></TR><TR><TD CLASS="quote">lol yea i'm looking to manage about 12.3:1 with those and a 2 layer headgasket, so it is probably a little more than a bit, but thanks for looking out</TD></TR></TABLE>
a setup like that would put you in the 13:1 range
Old Apr 24, 2005 | 01:52 PM
Default Re: CTR pistons w/ Type R rods? (sticky icky)
are you sure? i put it into the cr calc and got 12.28.
Old Apr 24, 2005 | 02:28 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xonefastackx &raquo;</TD></TR><TR><TD CLASS="quote">are you sure? i put it into the cr calc and got 12.28.</TD></TR></TABLE>
i used http://www.zealautowerks.com
Old Apr 24, 2005 | 02:39 PM
hmmm yea i see now. well that one is a lot more specific then the one i used, so maybe not everything was covered, i used http://www.bojangs.com/calculator/
futureracecar
Feb 26, 2010 11:37 AM
hybridpatient95
Aug 6, 2005 04:25 PM
KoRE
Mar 3, 2003 01:04 PM
Skunk2_92gsr
Dec 18, 2002 07:54 PM
importadrenelin
Aug 10, 2002 10:13 PM
