Whats rods do I need to use to put CTR pistons in my B18C5?
Whats rods do I need to use to pu CTR pistons in my B18C5?
EMERGENCY..
What Rods will fit CTR pistons into my Type R? The CTR Rods are .001 of an inch to wide and were sending the Pistons & Rods to the shop tomorrow to have the CTR pistons put on the ITR rods but will this even work??
Please let me know ASAP?
Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (Chris)
are you absolutley sure? are there any mods that I may need to do in order to have the pistons fit that rod???
Advid please
Advid please
Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (importadrenelin)
He is absolutely sure, as am I.
You only need to modify the CTR pistons if you are putting them onto non type r rods.
Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (AJ PwR)
hey so do I use the ITR Rod Torque Spec or the CTR Rod Torque Spec because I'm using CTR Pistons.
Thanks
Thanks
C5 with CTR pistons
wont your comp be a little high? What cams are you going to use? Piston/Valve clearance w/ say JUN 3's...........would the CTR's have enough room?
I was thinking B16a pistons for my R motor and that was a little over 11.5:1
B16B pistons would have a C5 well over 12:1 maybe even 12.5:1
Pump gas friendly? More info on your setup would be nice...........maybe post a dyno of before and after your new pistons
Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (SergEK)
Hey,
Actualy were using a B16A head with a Port and Polish Stage 3. Were running all CTR Valvetrain and CTR Pistons on ITR Rods. Using Bojas Calculator our Compression is 12.1:1. At least 94 Octane Gas will suffice, but to be extra safe just get the additives.....
Use the specs from a 73 Chevy 454 BB. I can't remember off the top of my head but I believe it's around 70lbs/ft.
Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (RyanR)
I though when you put ctr pistons in a itr you need to you prelude s torque specs
C5 with CTR pistons
Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (C5_ALLMOTOR)
itr rods are the ones you need, be prepared to detonate
Leave him/her alone...
HELP! NEED TO KNOW RIGHT AWAY!!! EMERGENCY!!!!
where's the fire? A Helms Service manual is your best friend.
Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (Michael Delaney)
sup retard. i'd love to know how you plan to torque you piston wrist pins. tard
D
D
tvrsir
12-07-2003 10:39 AM
