trouble with swap
Old Apr 16, 2005 | 12:31 PM
coreypoppej6's Avatar
Default trouble with swap
I have 98 civic dx hb, and i'm putting in a d16z6 with a Jackson Racing supercharger. i have a p28 ecu and obd2 to obd1 conversion harness for the swap to work in my car. my question is what do i do about the engine harness. the harness on my stock engine doesn't have a vtec solenoid plug. does the harness on the d16z6 that i'm putting in plug into the chassis harness. Please help
Old Apr 16, 2005 | 12:38 PM
roycivic92's Avatar
Default Re: trouble with swap (coreypoppej6)
well do the most common run a wire from the ecu to the vtec and ground the black wire on the same bolt near the vtec
Old Apr 16, 2005 | 12:42 PM
Default Re: trouble with swap (roycivic92)
do you know exactly what wire on the ecu i should tap? also, so if i do that i can use the harness on the d16y7 that is in my car now
kodamoose420
Nov 13, 2013 03:10 AM
Hatchbacksonly
Nov 10, 2012 03:09 PM
PaChiLa Leader
Nov 8, 2008 10:52 PM
crazy sohc vtec guy
Mar 25, 2007 12:52 AM
Tyreece04
May 10, 2004 04:38 PM
