Oil return line size and type?
Old Apr 16, 2005 | 08:36 AM
vtec.dc2's Avatar
Default Oil return line size and type?
Right now i got -10 AN compressor fittings that been leaking forever.. i'm sick of adding oil and switching to rubber line with clamps and heatwrap. Besides, braided return line is rubber on the inside.. so not much difference at least it will seal
Now, heres my question. I searched and some say to use 5/8 some say 3/8.. which should I get? Also, would red heater hose be good enough for oil?
Thanks
Old Apr 16, 2005 | 09:46 AM
stealthmode62's Avatar
Default Re: Oil return line size and type? (vtec.dc2)
some say 5/8 and some say 3/8 for what????
Use a hose that is rated for oil and can withstand the temps. Anywhere you find the right hose will be able to tell you if it is rated for these things.
The rest of your question I can't figure out.
Old Apr 16, 2005 | 07:42 PM
vtec.dc2's Avatar
Default Re: Oil return line size and type? (stealthmode62)
my other question is what size do i use if currently running -10 AN line? would it be 5/8th inch?
Old Apr 16, 2005 | 09:41 PM
SHystrdyGSRtdy's Avatar
are you asking 3/8" or 5/8" FITTING SIZE?
Old Apr 16, 2005 | 10:00 PM
vtec.dc2's Avatar
Default Re: Oil return line size and type? (SHystrdyGSRtdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">are you asking 3/8" or 5/8" FITTING SIZE?</TD></TR></TABLE>
i'd like to know what diameter (in inches) i need to run for my return line. fittings i have are -10 AN
Old Apr 16, 2005 | 10:53 PM
http://www.magnumforce.com/earls_hose.asp
have fun
btw: -10 = 9/16" (I.D.)
Old Apr 17, 2005 | 05:04 AM
vtec.dc2's Avatar
thanks!
Old Apr 17, 2005 | 08:26 AM
non-VTEC's Avatar
get some 1/2" high pressure hydraulic hose from your local industrial center.....that stuff is the same thing the "braided" hose is made of just it doesn't come braided....and its only a few bucks a foot.....
Old Apr 17, 2005 | 01:39 PM
vtec.dc2's Avatar
Default Re: Oil return line size and type? (non-VTEC)
i found some red hose, but only in 3/8" ID.. is that too small for return line?
Old Apr 17, 2005 | 01:56 PM
i wouldn't risk it... blown turbo seal or a few bucks in return hose? it's 3/16" of a diff...
Old Apr 17, 2005 | 02:05 PM
vtec.dc2's Avatar
i'm not going to.. guess i'll wait till monday.. i think they had larger heavy duty hoses.. like 3/4" or 1/2".. do i need to change fittings as well or i can just clamp it over existing -10 an
Old Apr 17, 2005 | 02:26 PM
not sure about that.. just take your fitting there and test it out i guess?
Old Apr 17, 2005 | 02:33 PM
vtec.dc2's Avatar
yep.. i'm gonna take apart then.. damn... i had a chance to get larger hose i just wasn't sure.. now gotta wait another day. that 3/8" was the largest in red hoses, but i guess not large enough
. thanks for helping out again
mrx
Oct 30, 2005 09:08 AM
i3oricua
Apr 28, 2004 10:38 AM
GSR x13
Dec 2, 2003 10:11 PM
Snail Tuning
Feb 1, 2003 08:44 PM
1.8T_EG
Sep 26, 2002 07:07 AM
